Squeking?
  • Thread starter Thread starter Boostin
  • Start date Start date Nov 30, 2004
Boostin
57
  • Nov 30, 2004
I have a 90 gt, and when the car is running you can hear this weird rattling/sqeeking noise coming from somewhere, it goes away when you push the clutch pedal in a hair. can someone help me out?
87GT 306
260
Springfield MA
Nov 30, 2004
  • Nov 30, 2004
mine does the same thing...someone told me it was the throw-out bearing, but I dont know for sure.
bryanrevans
296
Chicopee,Mass
Nov 30, 2004
  • Nov 30, 2004
I had same thing I adjusted my clutch cable tighter just a bit.Its the clutch fork shippyin or bounceing.It drove me crazy!!
bryanrevans
296
Chicopee,Mass
Nov 30, 2004
  • Nov 30, 2004
Now I thought the throw out bearing was bad but did same thing when new one was threw in.pita
Boostin
57
  • Nov 30, 2004
K ill try tightening the cable then
sprayed88stang
31
ltown
Nov 30, 2004
  • Nov 30, 2004
help
put in a new throw out bearing sounds like its going bad adjusting it will work for a little
HISSIN50
34
129
Dec 1, 2004
  • Dec 1, 2004
common solution to the squeak is to preload the clutch cable (just as you do when you push the clutch pedal ever so slightly).
but i would not necessarily leave a noisy TOB in there.
good luck.
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
1998 Mustang Gt Rattling sound, cannot locate. Video included
  • studerman1
  • Mar 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 1, 2026
studerman1
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
