Stalling Issues After Hci Work
  • Thread starter Thread starter acoddo
  • Start date Start date Aug 24, 2017
acoddo
84
23
28
Aug 24, 2017
  • Aug 24, 2017
So I'm still trying to figure out why she won't idle right.. cobra intake, f303 cam and aluminum heads with 24# injectors and 24# maf. Haven't installed the better fuel pump yet.
Every time I start it, the idle either jumps around a lot or it stalls. I've adjusted the TPS a bunch but I'm out of ideas. Anyone know??
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Aug 24, 2017
  • Aug 24, 2017
Have you checked for a vacuum leak? Will the car run if you keep the rpm up? Backfire choking popping?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 24, 2017
  • Aug 24, 2017
You guys with idle/stall problems could save a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first two posts have all the fixes, and steps through the how to find and fix your idle problems without spending a lot of time and money. It includes how to dump the computer codes quickly and simply as one of the first steps. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix.
It's free, I don't get anything for the use of it except knowing I helped a fellow Mustang enthusiast with his car. At last check, it had more than 250,000 hits, which indicates it does help fix idle problems quickly and inexpensively.
acoddo
84
23
28
Aug 24, 2017
  • Aug 24, 2017
Thanks for the link. I'm not familiar with these forums too much. And I had the whole system checked for vacuum leaks and vapor tested
General karthief
Mod Dude
Aug 25, 2016
28,101
10,715
213
polk county florida
Aug 24, 2017
  • Aug 24, 2017
Take a deep breath, make sure your wiring and all the grounds have good connections, go throught jrichker's surging idle checklist, you'll find something you missed.
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
