Stand alone nitrous fuel system
  • Thread starter Thread starter steel1212
  • Start date Start date Aug 28, 2005
steel1212
1,180
Frankfort, Ky
Aug 28, 2005
  • Aug 28, 2005
Well I'm pretty much done with the hard work now all I have to do is wire up all this crap lol. Here is a pic of my stand alone fuel system. I'll have more pics over the next few days.
The fuel cell is a 4 gal rci unit and on the other side is a holley blue pump running to 6 an line down the left rear rail take a right to the front of the stock tank and the from the middle up through the tunnel on the passenger side. It comes out on the passenger side right above the heater motor and connects to a reg and then from there to the fuel solenoid. (more pics soon).
The nitrous bottle sits on a heated cradel with a pressure switch that keeps the bottle to with in 50 psi of what you set it at.
R
race-rodz
44
  • Aug 29, 2005
so what are you doing for "wiring" ? this is similar to my set-up.... sans i used a 2 gal cell, i also ran the "wiring" on a throttle switch along with the "button" just in case of a missed shift.
R
Rajun_Cajun
21
San Diego, Calif.
Aug 29, 2005
  • Aug 29, 2005
What does "Stand Alone" mean?
steel1212
1,180
Frankfort, Ky
Aug 29, 2005
  • Aug 29, 2005
Its seperate from the cars fuel system. Its just for the nitrous.
For wireing I use a purge, WOT, FPSS, and a window switch. All this activated through a dynotune control center.
10secgoal
2,801
San Diego
Aug 29, 2005
  • Aug 29, 2005
You should look into putting one of the switches on the clutch pedal. On the bottle, you will never react fast enough to keep the motor from over reving, unless you have a revlimiter. Say you shift at 6k, you only have a few revs left until it starts sling parts thru your block.
Steel, is it an optical illusion, or is the feed line for the fuel pump not at the very bottom
R
race-rodz
44
  • Aug 29, 2005
i do have a clutch switch also.......... got distracted when i typed the reply.
steel1212
1,180
Frankfort, Ky
Aug 29, 2005
  • Aug 29, 2005
I have the window switch to cut of the nitrous at about 6200 when I shift at 5500. Is that what your talking about? I have th 6al and it has a rev limiter set at 6500.
ALso yeah its at the bottom. The pump is directly off the cell via an elbow and the line comes of the pump straight down.
R
race-rodz
44
  • Aug 29, 2005
with a NO2 managment unit you are a lot safer in case of missed shift..... bad things tend to happen when you hit the rev limiter on the juice.... so as long as your management system shut it down before the rev limiter... your good to go.
steel1212
1,180
Frankfort, Ky
Aug 29, 2005
  • Aug 29, 2005
Yeah thats why the window switch will be set at 6000-6200 rpms and the 6al will be at 6500 or so. The window switch should shut it down before it hits the rev limiter. That way no nos is building up in the cylinders.
10secgoal
2,801
San Diego
Aug 30, 2005
#10
  • Aug 30, 2005
  • #10
You guys are set, and safe then. I went to test the system once and scootched my butt in my seat to readjust when i tested the system. tapped the gas pedal when I was already holding it a 3k. I mean I barley tapped it. revved straight to 8k.
M
mustangman70
1,235
St pete, Florida
Aug 30, 2005
#11
  • Aug 30, 2005
  • #11
How do ya liek that bottle heater???? I have the exact same one and i LOVE it, pressure stays right where it should
Ill post up a few pics of my trunk setup in a couple of days
steel1212
1,180
Frankfort, Ky
Aug 30, 2005
#12
  • Aug 30, 2005
  • #12
Don't know yet I'm still in the process of runing all these wires for this switch and that module lol. Hell the control center has 7 wires just for it!
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
H
Fuel filter relocation?
  • hecdawwg
  • May 7, 2024
  • 2 3
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2024
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
