I've made the decision that I will be getting a stand alone for my car in the next year or so. I don't know how much info I'll get here on the subject, but I figured I'd post it up for discussion anyway.
I heard a lot of bad things about the AEM when it first came out, but I recently had the chance to see it in use in my buddy Mike's 9 second fox body. He went through and showed me the datalogs and how there are a number of extra inputs that can be converted to read virtually anything that you can import with a voltage. I was REALLY impressed with it and its capabilities. He informed that when it came out it received some bad press because some notable tuner said that the timing varied greatly between each cylinder. Mike has checked his and sees nothing of the sort. I really like that it is basically a plug in deal with minimal wire splicing. I think, though I'm not positive, that some of the others such as fast and the like require you to splice it into the cars wiring. Can anyone confirm this? I also liked the fact that I can run speed density or a MAF with the AEM. I think I'll run it via speed density so that I can help offset some of the cost of the stand alone by saving on buying a new MAF meter.
