Engine Standard or hi flow water pump?
  • Thread starter Thread starter AnthonyA1234
  • Start date Start date Sep 28, 2026
AnthonyA1234
5 Year Member
Aug 17, 2020
674
111
63
Florida
Sep 28, 2026
  • Sep 28, 2026
Looking to change the water pump on my 92 GT. It’s a HCI modded car and I live in Miami with super hot temps.
Is there an advantage to high volume pumps or should I stick with standard?
And what about fan clutches? Are the heavy duty’s the ones to get or are they super loud?
Admin Dude
Jan 4, 1985
43,565
21,736
234
Box behind Walmart
Sep 28, 2026
  • Sep 28, 2026
My rig is an all-street, 480ish HP boosted combo with a 3-core aluminum radiator and a standard volume water pump with no cooling issues.
I use an HD fan clutch and if it's louder, I can't hear it over the engine and exhaust. It does clean the leaves off the driveway at idle.
Reactions: DadLife0724, General karthief and Mcmahst
AnthonyA1234
5 Year Member
Aug 17, 2020
674
111
63
Florida
Sep 28, 2026
  • Sep 28, 2026
My main issue is I’ve gone through 4 different fan clutches and they all WOOO like a supercharger after like 2 months of use. It’s embarrassingly loud especially when I rev the engine. My water pump pulley is slightly crooked so I believe maybe that’s making my clutches go bad quickly?
I guess I’ll try replacing the water pump with a motorcraft unit and putting a heavy duty fan clutch. I can use the extra fan power, my ac always struggles when the car is at a stop.
Admin Dude
Jan 4, 1985
43,565
21,736
234
Box behind Walmart
Sep 28, 2026
  • Sep 28, 2026
The crooked pulley would concern me too.
The other thing is that you may not need an HD fan clutch at all. That's a longer convo but the short of it is that they [tend] to lockup a little sooner. There are instances where this is not always the case.
Is your fan shroud in good shape?
AnthonyA1234
5 Year Member
Aug 17, 2020
674
111
63
Florida
Sep 28, 2026
  • Sep 28, 2026
Yea my fan shrouds good.
So you think I should do a SD or a HD clutch?
Admin Dude
Jan 4, 1985
43,565
21,736
234
Box behind Walmart
Sep 28, 2026
  • Sep 28, 2026
If you are concerned about the noise and have experienced noise from an HD before then try it.
The HD clutch holds harder at high rpm (which for a street engine at 6250 rpm max, is not a big deal) and little stiffer at the low end and idle. With my 3-core, I chose the HD [because] of the extra stiffness on the low end and because when I built my engine, my factory clutch was still installed (might have even been good still).
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Sep 29, 2026
  • Sep 29, 2026
I put an Edelbrock water pump on my car in 1999 and its still fine all these years later, have a funny feeling the quality of them today is probably not the same.
Reactions: DadLife0724 and OX1
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Sep 29, 2026
  • Sep 29, 2026
I have a 3 year old edelbrock on mine and it's been doing fine. Granted I don't drive much.
I think the Edelbrock and Flowkooler have what is considered a high volume impeller design.
Reactions: Shakerhood
F
fasterthangas
290
92
38
Phoenix
Sep 29, 2026
  • Sep 29, 2026
In hot climates, a high flow water pump is a good investment. Along with it you should use a high flow T-stat. I'm in Phoenix and use both. I think my water pump is a high flow unit from GMB.
Electric cooling fans are the way to go in your climate.
AeroCoupe
6,243
4,334
183
Claremore, OK
Sep 29, 2026
#10
  • Sep 29, 2026
  • #10
It’s more of an investment but a large core two row aluminum radiator will help immensely with a good fan (mechanical or electric).
I ran and still run a Mark VIII fan, Motorcraft standard volume pump, and a Fluidyne radiator. With the AC on in Houston traffic I never had an issue and it’s been great in the Oklahoma summers.
Try a new pump and get ride of the crooked water pump pulley. Check the radiator and AC condenser fins and make sure the air passages are not blocked with debris. If they are blocked pull the radiator and power wash the AC condenser clean. Check the radiator and clean it if necessary. I’ve seen AC condensers with debris and just cleaning it out fixed the problem being they are in front of the radiator. If it’s still getting hot make damn sure the fan clutch is locking up when needed and if not replace it. From there if it is still getting too hot replace the radiator with a quality aluminum unit.
Reactions: Shakerhood and General karthief
nickyb
I gotta say i never painted my nuts, Never Ever
3,063
1,679
163
nevada
Sep 29, 2026
#11
  • Sep 29, 2026
  • #11
FTW go electric. My black magic fan has kept my stang cool in Vegas baby aka( surface of the sun).
nickyb
3,063
1,679
163
nevada
Sep 29, 2026
#12
  • Sep 29, 2026
  • #12
Hay that rainbow is not funny,.ok a little funny.
Reactions: Noobz347
rednotch
I'd like to remain having one chocolate starfish
1,528
725
143
south jersey
Sep 29, 2026
#13
  • Sep 29, 2026
  • #13
Standard... Air flow over the radiator and coolant having time to disapate Heat is way more important than a water pump with an anti cavitation plate or aggressive fins design claiming it flows more. Its a self contained system, more flow rate means little for cooling.
Reactions: AeroCoupe
Admin Dude
Jan 4, 1985
43,565
21,736
234
Box behind Walmart
Oct 2, 2026
#14
  • Oct 2, 2026
  • #14
You already have an epic CT so, what's an Admin supposed to do?
Reactions: nickyb
AeroCoupe
6,243
4,334
183
Claremore, OK
Oct 2, 2026
#15
  • Oct 2, 2026
  • #15
What did I miss with the rainbow???
H
highplace11
31
Atlanta, GA
Oct 3, 2026
#16
  • Oct 3, 2026
  • #16
There is no such thing as not enough flow from a water pump, buy what fits your budget.... ALWAYS...
Mark
2000xp8
SN Certified Technician
Aug 8, 2003
8,077
1,659
194
NJ
Oct 9, 2026
#17
  • Oct 9, 2026
  • #17
The faster the coolant flows the shorter time it has to cool.
Sorta the same idea as why a 160 degree thermostat can be counterproductive.
So unless you have a massive radiator, i just don't see the point.
As for a crooked pulley, that's the kind of thing that tears up belts.
Reactions: General karthief
Engine Which fan clutch ?
  • AnthonyA1234
  • Jun 22, 2026
Fox 5.0 Mustang Tech Sep 19, 2026
Mustang5L5
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
