Stang backfiring after Cobra intake install...what's the problem?
gruvee87vertgt
Oct 7, 2003
272
26
28
Chicago, Il
Well, I check for a foul plug and checked the wires for the correct firing order and still backfiring. We removed the distributor and i think that has something to with it??? any suggestions is appreciated. thanx
Yeah, sounds like the distributor is off. I had the exact same problem when I did my Cobra intake install.
I even marked the distributor prior to removal.
I ended up playing around with it and got it put back properly.
Good luck!
I forget how exactly but I jsut play with it till it goes in right. You jsut keep starting the car and when it feels good it's in right. If it's off you'll know it
Putting the distributor back in is fairly simple. Pull #1 sparkplug, put your finger in the sparkplug hole, crank the engine until you feel compression. Then line up the TDC mark on the balancer with the pointer on the engine block. Align the distributor rotor up with the #1 position marked on the cap, slide the distributor down into the block, (you may have to wiggle the rotor slightly to get the gear to engage) and then note where the rotor is pointing. If it still lines up with #1 position on the cap, install the clamp and bolt. If not, pull it out and turn 1 tooth forwards or backwards and try again. Put the #1 spark plug back in and tighten it down, put the clamp on the distributor, but don't tighten it too much, as you will have to move the distributor to set the timing. Note that if it doesn't align perfectly with #1 position, you can turn the distributor until it does. The only problem is that if you are too far one way or the other, you can't turn the distributor enough to get the 10-14 degree optimum timing range.
At this point hook up all the wires, get out the timing light and start the engine. Set the timing where your car runs best. Don't forget to disconnect the SPOUT jumper connector when you set the timing, and plug it back in when you finish.
