I recently bought a 68 fastback (original J code) with the original motor that has been rebuilt. The PO had no idea what he was doing and built it with mis matching components.
I've stripped everything off the motor and here is what I have to work with
fresh 306
TRW forged flat tops .004 in the hole with 2.7cc of dish
Eagle I beam rods
Stock crank turned .10
I have these heads sitting on my shelf that I bought a long time ago that I'm going to use:
World Windsor Sr. heads with mild port work
milled to 62cc 2.02/1.6 valves which give me 9.51 compression with a .039 head gasekt
crane dual valve springs and the PO used a 294S solid roller camshaft
Motor has original A/C and power steering so I'm not sure how much that would affect the performance of the motor.
Basically I wanted to go a solid flat tappet (save me buying new valve springs), and I was thinking of going with a comp cams 282S dur @.50 236 .578 lift with 1.7 rockers and a 110lobe separation.
Would you guys reccomend going with a single profile or split profile cam with this situation? I was also thinking of running a 150 shot of nitrous down the road when I get enough time to install it(I already have it sitting on my shelf) I hear that more exaust duration is good for using spray
I have a tremec 3550 so I'm not worrid about the stall, but I also don't know what rear gear I have(but will soon be either a 4.10 or 4.56)
I was going to get a victor jr intake and I already have a speed demon 750 mechanical secondary carb sitting on my shelf.
What do you guys think, and do you have any reccomendations on how I should do this differently?
fresh 306
Eagle I beam rods
