Well, I've been trying very hard for 3 years to solve some problems on my 88 GT, reading hundreds of posts, trying dozens of things, spending money, still no solutions.
Here's what I've got, then I'll try to describe my woes quickly...
88 GT, AFR 165 heads, 1.5L Kenne Bell blower with 9psi pulley, 24 lbd ford motorsport injectors with 93 cobra ECM (new from ford motorsport), mass air conversion, new: TFI, cap, rotor, wires, plugs, ACT, ECT, coil, TPS (0.995V at closed throttle), IAB, 255lph pump, fuel regulator, fuel filter, insulation wrap on headers, located ACT in cold air intake tube
Probs:
1. Cold start - starts, but dies, will then start and idle after a couple tries, but give it gas and it will nearly stall. After 2 minutes, all is well! Very difficult to drive first 2 minutes.
2. Hot start - run it till fully warmed up, let it sit for 15 minutes, then it will start and imediately die. Repeat oever and over, it won't keep running but will monentariy run each time I try to start it. If I give it gas I can keep it running, but it's rough. I rev it for a while and it clears up and will then run fine. Vapor lock? If I let car sit with hood open after running this will not occur.
note: This hot start prob did not exist before mass air conversion and cobra ECM, and 255 lph pump were installed, but blower was installed.
3. run up the rmp on accleration, let off, then it idles high, anywhere from 2-3K rpm. If I snap he throttle fast and hard it will come back down. I disconnected cruise control cable to elliminate that possibility. No difference. I can shut engine off while it idles fast, restart in 2 seconds, and idle speed is normal! So two things can return idle to normal: 1, snap throttle, or shut off engine and restart it right away. Mechanically I can find no bind or trouble, the throttle butterfly returns to the stop just fine, doesn't appear to be slightly stuck open. Seems like computer gets confused..?
4. After warmed up, loss of power at rpm above 3-4K. It feels like it cuts out power, then back in to power, then out, so it jerks several times per second when pulling hard. This does not happen with ACT in intake manifold connected to ACT harness, it just has low power all the time after warm up. I move the harness to the ACT in intake tube and the power is great, until fully warmed up and higher rpm then it quickly cuts in and out. When cold it pulls really hard past redline. Definitely seems engine temp related and it seems the ECM gets confused and cuts power back. IT is a very noticable difference.
I can live with probs#1 and #2 if I have to, but not with #3 and #4.
Error codes:81, 82, 95. Interesting, all Thermactor stuff. I think the '93 cobra ECM is not compatible with the wiring to the solenoids for the thermactor circuits in my '88. Anyone know? would this cause any driveability probs? I thought it would only effect emmissions. But maybe my hot start prob is rooted here?
I really need some help, I'm spinning my wheels. Thanks!!
Probs:
