Starter Bolt
  • Thread starter Thread starter 89mustanglx50
  • Start date Start date Jul 27, 2004
89mustanglx50
38
  • Jul 27, 2004
Does anybody have any tips on removing the upper starter bolt on an 89 5.0? I believe it has the older style starter, but i cant get to the upper bolt. does anybody have any tips on how to get it off? thanks.
andrew
The Shape
2,224
East ARKANSAS Delta
Jul 27, 2004
  • Jul 27, 2004
He is right you need as many extensions as you can find. You then go from the front of the car under the header to get at it.
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jul 27, 2004
  • Jul 27, 2004
i can get to mine fairly easily from under the hood. but if you have your smog equipment there its out of the question unless you take it out. just use a long extension. you wont be able to turn the ratchet that much but you can get it out
88TurboFiveO
10
Denver, CO
Jul 28, 2004
  • Jul 28, 2004
andrew
I have found that removing the passenger side front tire will give you access to the upper starter bolt. Good luck.
ironmedic
1,361
Puyallup, WA
Jul 28, 2004
  • Jul 28, 2004
u can also do it through the k-member as well. there is a small gap in there somewhere to get your hand in there. would be easier to remove the passenger tire to access it as stated above.
Ozz
I think I have a problem here.
3,514
66
109
Canton, MI
Jul 28, 2004
  • Jul 28, 2004
I do mine with the tire in place and all my smog crap in the way - by doing what IronMedic said and sliding the extension/socket through the K-member. Works like a charm.
V
v8only
2,378
22
49
Jul 28, 2004
  • Jul 28, 2004
i've gotten in there with as few as one long extension, don't remove anything. Just grab some extensions as mentioned and go in there and remove the bolt.
hllon4whls
BANNED
2,567
Covington
Jul 28, 2004
  • Jul 28, 2004
There is such a thing as a wobble extension. They allow the socket to literally wobble around. I got a cheap set from harbor freight . They help a bunch. You would be surprised how much that little bit of movement will help you get into tight places.
Paully's5.0
495
WI
Jul 28, 2004
  • Jul 28, 2004
I took off the passenger tire as well, used a bunch of exetensions and a universal joint, finally got it off.
Now you get to spend the next 30mins fumbling with the starter until it is in the right position to slide out from underneth. Gald I replaced it with a mini starter!!
9
9 Deuce GT
550
Geneva, NY
Jul 29, 2004
#10
  • Jul 29, 2004
  • #10
Hopefully you don't run into the same problem I did. The top bolt was frozen in there, (no anti-sieze). The head of the bolt broke off and I had to drill it out. Sucked donkey balls.
Euphoric306
905
#11
  • Jul 29, 2004
  • #11
man that sounds like it sucks. i just replaced starter and had to turn the wheel and go thru the k-member (i think thats what it was, the metal thing with the hole just big enough for your hand to fit through) to get the top bolt and the wire connecting bolt. when i pulled the starter out and then put the new one in my tranny cooling lines got tweaked and messed up the o-ring inside the fittings at the tranny so i ha to replace the fittings. car was down for two days but now i got a rebuilt starter that sounds great. luv it oh btw, no extensions cept a 2 incher. wobblies u cant torque the bolts as much as they need to be torqued right? ive tried using those before and theyre great but i find it hard to get the bolts snug with those, just my experiences thanks for listening and tune in next week for the dramatic finale
Stang89LXCPE
88
Wooster, O-HI-O
Jul 29, 2004
#12
  • Jul 29, 2004
  • #12
glad to hear you got it out. They always were a pain. I like my longtubes and no smog, easy access top and bottom.
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
Engine Starter ring gear depth. 3/8 or 3/4 inch?
  • 92Rustang
  • Aug 4, 2025
Fox 5.0 Mustang Tech Aug 22, 2025
Rcdgl
R
Electrical Mini-Starter Wiring
  • RekeHavoc
  • Jul 25, 2025
2K
Fox 5.0 Mustang Tech Aug 24, 2025
Mustang5L5
coil pack bracket
  • SteveG94GT
  • Apr 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 11, 2026
SteveG94GT
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
