Starter going AGAIN!!
  • Thread starter Thread starter mustang120plus
  • Start date Start date Jun 13, 2005
M
mustang120plus
261
Michigan
Jun 13, 2005
  • Jun 13, 2005
Ok...damn starter...
I have this problem (this is my third starter) where my starter will work normally for a while and then it "sticks" on startup. It will keep going like the gear is still engaged.
I have heard some people say that high levels of heat can cause this. I have shorty headers...is this the case?
I wouldnt mind cause I have a lifetime warranty on my starter via autozone but they are the biggest pain in the a$$ to change out
stang22
1,318
Washington, D.C.
Jun 13, 2005
  • Jun 13, 2005
How many months are you getting out of your starter? Do you have them tested when they go bad? Long tubes can kill a starter and they will start to suffer from "heat soak", but not always. They ussually don't have the symptoms that you are getting though. Check all of your grounds and double check all of the connections at the solenoid. Bad grounds can cause strange things to happen.
Tim
M
mustang120plus
261
Michigan
Jun 13, 2005
  • Jun 13, 2005
Tim
I probably get about 4-6 months out of a starter. But in Michigan I only drive my car during the summer anyways..so it seems that I am replacing one every summer.
I dont have long tubes I have bbk shorty's. I dont know. I was thinking about wrapping my headers to see if that changes. My headers look like crap anyways because they are all heat scorned and what not.
stang22
1,318
Washington, D.C.
Jun 13, 2005
  • Jun 13, 2005
You can wrap your headers and get a heat shield for your starter if you think that is killing it.
Tim
Big Posi and Neg wire from Starter to Battery and Alt wires..........
  • from6to8
  • Feb 9, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 9, 2026
AeroCoupe
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
