put a 01 vic engine in, thinking it was pi when purchased. unfortunately it is nonpi but kept it anyways, now the car started and ran fine for having a serious knocking sound, i went ahead put the 01 vic engine in swapping alot of stuff, timing cover, pi intake, ac compressor, and flywheel, and small things here there. i plugged all my sensors back in, and put everything where it was when i started. except for this grounding strap that was located on the driver side block, which is a red strap. i have no flippin idea where the other end goes to. the red strap mounted to the block also had a black wire mounted w/ it. this strap couldn't keep my shatstang from starting could it? i put a new starter in it because it wasn't engaging (hitting flywheel or turning over the motor, but the new one is doing the same thing. i am at a loss right now, could the flywheel be culprit here? if i take the trans out, how will i know if the flywheel and crank is at correct alignment? all the bolts lined up just fine when i put the flywheel on, but i didn't stop to think the flywheel was to be at a certain point or alignment. but hopefully u guys have an explanation that will save me from pulling out the trans. plz help i about to just junk it, that's how tired of this lemon i am. and sorry about the novel.
