  • 1994 - 1995 Specific Tech
starter problems with '94, help!
  • Thread starter Thread starter greenstang1313
  • Start date Start date Dec 7, 2009
G
greenstang1313
158
Chelmsford, MA
Dec 7, 2009
  • Dec 7, 2009
I have been having starter problems with my '94 Cobra for as long as I can remember. I have owned the car for about 4 years and Ive had at least 4 starters in it. The car just loves to burn through starters. I put a new starter in it last week and I just went to get in the car and the new starter is crap already. Does anyone know what the problem could be? Could it be something to do with my aftermarket flywheel? Any help would be awesome.
302GTS
If you need herpes, I'm your man!
Apr 20, 2009
481
Largo, FL
Dec 7, 2009
  • Dec 7, 2009
One look at your signature points me in the right direction. Longtubes are notorious for coming realll close to the starters in our cars. That could kill one in no time.
G
greenstang1313
158
Chelmsford, MA
Dec 7, 2009
  • Dec 7, 2009
funny you mention that, when i was replacing the starter last week I noticed for the first time that the LTs are practically touching the starter. are you saying the heat from the headers is killing the starters?
Black95GTS
1,644
Marlborough, MA
Dec 7, 2009
  • Dec 7, 2009
Bingo. Header wrap or after market starters, could fab up a heat shield... I've never had the problem so perhaps someone who's experienced can chime in with pictures.
Adam
HISSIN50
34
129
Dec 7, 2009
  • Dec 7, 2009
You can also buy a prefabbed heat shield if that's easier......
Bosko5.0
1,067
longwood, FL
Dec 7, 2009
  • Dec 7, 2009
I used header wrap and big hose clamps on my stock starter And it starts fine.
They make starter wrap, not sure how much it is though.
302GTS
Apr 20, 2009
481
Largo, FL
Dec 7, 2009
  • Dec 7, 2009
That'd be the problem, OP - most definitely. It's real common for 5.0 guys throwing LT's on their cars to kill starters. I had a friend of mine with a fox who killed them once a week. He got a mini-starter, and also wrapped the header to solve the issue. If you're looking for the 'cleanest' look, I believe Adam95gt on here bought LT's from Accufab that were made to fit and clear the starter, but I'm not positive on that.
G
greenstang1313
158
Chelmsford, MA
Dec 7, 2009
  • Dec 7, 2009
thanks for the help guys!
G
greenstang1313
158
Chelmsford, MA
Dec 7, 2009
  • Dec 7, 2009
a couple friends just told me not to use header wrap because i drive my car too much. is it a bad idea to use wrap if i drive my car almost every day?
Hef5.0weisen
20+ Year Stangneter
Mar 5, 2004
574
NorthWest Florida
Dec 7, 2009
#10
  • Dec 7, 2009
  • #10
no doubt longtubes could be the culprit, however, just curious as to what is happening to said starters??
I was having some trouble with mine being intermittent, wound up being a loose ground. Just some food for thought....the parts stores will throw them on a tester, or when one goes bad.... give it power (spare battery or just use some jumpers) and a ground see what happens,might help in troubleshooting if it persists...just a thought...
good luck
R
Flex plate and starter issues
  • RJH46
  • Jun 24, 2025
  • Other Auto Tech
Other Auto Tech Aug 19, 2025
nickyb
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
C
Starter Solenoid
  • Chrispy62
  • Sep 7, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 7, 2024
