Starter Relay Question?
Stroked91
25
I have a 91 GT with a lot of accessories. Amp., 3G alt, alarm, relocated battery, power cooler, etc. Now I want to install a dual electric fan and there's no more room at the starter relay. The nut is flush with everything that I have tied into it. Anyone have any suggestions on a good clean way to resolve the problem?
Sean
ummm, the positive battery post. :)
also, some aftermarket solenoids have shorter lugs than oem solenoids - if you have the former, maybe check out getting the latter.
good luck.
Hey HISSIN, Yeah I thought about that (actually my first thought), but my battery's relocated to the trunk and I'm no electrical wizard, so what dia. wire do I need to use for the 20 amps. that the fans are going to pull? I have part of a roll of the 10 ga. left over from the batttery relocation that I used for the computer ground? Anyone have ideas? If I hook the fans directly to the battery, they should turn off automatically through the controller. Right?
The starter relays for 93 & later supposedly have longer studs.
I would check with the local auto stereo shop for a power distribution block. I have seen some nice looking ones that would do the trick.
As far as wire, the 10 gauge wire will work fine if you decide to go that route.
JR comes through again. :nice:
some distribution blocks are made to flow some serious power and that should work really well. your solenoid is sorta' acting as a distribution block right now, as it is. :)
good luck.
Thanks Guys! I ended up grabbing it from the alternator. My twin fans work great and come and off when they're supposed to and only stay on for 10 - 15 seconds after I turn the car off.
