hot starting when hot help 91 mustang
Chadkelly
Saskatoon
Hi everyone I have a 91 mustang hot start problem when running after 20 minutes the battery is new but it’s not a big one? I would like a bigger one like a ?group 65 battery with more cranking amps .
it’s been a very big headache for me any help or tips to try I would greatly appreciate it . The car has the battery relocated New 2 gauge wire to factory locations up front . then from the solenoid I did a 4 gauge wire to starter. With a new a 14gauge? Signal wire.
This what’s all New new on it ? Starter distributor coil plugs wires
Map sensor
headers that are warped. Long tube
Tin diy heat Shield. Heat warped the starter wires too
I added 2 ground wires in the back
New alternator 3G set up
Tps sensor set
Timing at 10
I did the volunteer drop down test and got a
With coil off got 9.63 volts off the battery
But it seems like it starts gd cold no problem so its ? My wires to the back of car 2 gauge then to 4 gauge to the starter and alternator?
It’s something electrical?
But I’m at not sure what test to do ? Next or what video to watch for more help ? Was even thinking? A relay ?
Please help me or give ideas and information on what I should do .thanks guys and girls..
This is a hard one because there are a lot of variables. Condition of cables, battery condition, ground locations.
Best I could advise would be a voltage drop test starting at the battery, just a thought, next time the hot start problems occur feel the cables starting at the battery up to the starter, this may give you a hint.
Search voltage drop test on YouTube. Once you have confirmed the cables are good then this thread may be of some help.
Check to see if your 22kohm resistor at pin #4 is still good by doing a ohms check between pin #4 on the ECU plug and Pin #2 on the TFI plug....
Another thing I would do is clean up the grounds for the ECU thats bolted to the unibody and change the ground wire between the battery and the engine block.
Sometimes the wires in the tfi plug lose connection and theres one wire on the TFI called the "Start Signal In" wire thats responsible for retarding timing while the engine is cranking..........
When the key is turned the "start signal in" wire at the TFI plug should show between 10.5 and 12.7volts
