  • SN95 4.6L Mustang Tech
Electrical Starter Replacement Issues
  • Thread starter Thread starter thatblackfoxbody
  • Start date Start date Oct 10, 2021
  • Tags Tags
    starter starter problems starter solenoid
thatblackfoxbody
18
11
North Carolina
Oct 10, 2021
  • Oct 10, 2021
Hey all, posting here because I'm running dry on ideas and need insight.
Car is a 1998 Cobra, not mine, it's a friend's car. Posting here because the starter on a 2v should not be any different of a job than on a 4v. Car has a slew of electrical issues, looks like the wiring was done by a barbarian and a 5 year old, and I'm helping him fix a lot of the problems.
Long story short, I determined the starter was going out because it would not turn over sometimes, but if I hit it with a ball peen hammer, it would turn over.
This car has kooks longtubes, and getting the new starter in was the biggest pain. Finally get the new starter in, and now the car will not turn over. The starter solenoid does not sound like it is engaging at all.
For details sake, the engine block ground has been cleaned, and the voltage from the red wire of the starter to the transmission/engine ground is 12.3 volts. I did have to remove the starter solenoid to squeeze the new starter into place, as we only shifted the oil pan to the left to fit the starter into place.
If the electrical connections are theoretically good, and two of the three starter bolts are really tight (there is no way in hell I can reach the third starter bolt), what else should I check for? Just trying to pick the internet's brain here. My immediate thought is the starter solenoid is not seated properly because we did remove it to fit the new starter in. If there is other troubleshooting that you all are aware of regarding starters, let me know. I do not believe it is the starter relay, because that was working fine before.
To be clear, the car is NOT turning over, the starter is getting 12.3 volts from a 12.3 volt battery all the time, and I do not hear the starter solenoid engage.
Thanks.
thatblackfoxbody
18
11
North Carolina
Oct 10, 2021
  • Oct 10, 2021
oh, and for even more clarity
brand new battery, brand new alternator.
thatblackfoxbody
18
11
North Carolina
Oct 10, 2021
  • Oct 10, 2021
Update: Shorted the solenoid bypassing the relay and running a jumper cable from the positive battery terminal to the signal wire. It turns over. Something is wrong with the circuit. The signal wire was only getting 5 volts.
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
R
Flex plate and starter issues
  • RJH46
  • Jun 24, 2025
  • Other Auto Tech
Other Auto Tech Aug 19, 2025
nickyb
T
Electrical 1990 Vert starting/Solenoid issues
  • Tom77
  • Apr 18, 2025
Fox 5.0 Mustang Tech Apr 18, 2025
85GTStangGuy
