Starter solenoid problems...
SilverSER
Well I posted a few days ago about how my 87 5.0 starter keeps staying engaged. So far I’m totally stumped at what could be going on. My problem is once the car is started, the starter will stay engaged until the battery is disconnected. So I’ve replaced all of the following…
Starter
Starter cable
Battery
3 Solenoids
Ignition switch
And the problem still occurs! :( I know the starter solenoid is a major part of the problem because I had the ignition switch out and connected the battery cable and it still tried to start. If I disconnect ignition wire from the solenoid and connect the battery, I read 50 volts on the ignition post of the solenoid. Is that a normal amount? Does anyone have any idea what could be causing these solenoids to lock up and go bad? :shrug: I’ve checked all the grounds and made sure none of the bolts were loose.
One additional thing, once a new solenoid is in place I can start the car normally one time. Once the car is shut off and I try to restart it, it goes back to square one. I’m not sure where to go next? Anyone, help please!! :bang:
HISSIN50 said:
50 volts is just a little high. ;)
What flavor of solenoid are you using?
Not sure what you mean by what flavor but the one i'm using now I bought at NAPA. When I bought it the guy asked if I wanted a regular one or a heavy duty one. Since i've already went through 3 I opted for the cheap one! Any idea what I might gain from the heavy duty?
Next time it happens, pull the small push on connector (red wire) off the starter relay (looks like it is stuck on a screw). If it quits cranking, the ignition switch is bad.
I had the same thing happen on my 85. Even after going to a push button. I had some one tell me to add an extra ground to the neg cable, and it worked. I don't know why, but it has done fine for over a year.
