I recently finished my Tremec TKO conversion. I used a Ford Racing mini starter because with a 157 tooth flywheel the factory (c-6 trans) starter was hitting on the block/oilpan. Fits good, but when I start the car and the engine fires up there is a squeling sound. It goes away in 3-4 seconds. It sounds like the starter is not retracting immeditely when key goes back to accesory position and the engine is spinning it until it does. I have both wires for the starter attached to the starter side lug on the fender solenoid. Any suggestions on fixes or a better starter?
