  • SN95 4.6L Mustang Tech
Starting engine after storage.
  • Thread starter Thread starter yjosh
  • Start date Start date Apr 21, 2007
Y
yjosh
  • Apr 21, 2007
Another question:
I'm getting my 02 out of winter storage tommorow. It hasn't been started in 6 months. I'm nervous about starting it as I'm sure the oil is all in the bottom of the pan and bearings are somewhat dry. Oil is Mobil 1 full synthetic 10-30. Am I paranoid?
My other cars are old old carburated, so I've just cranked them over until oil pressure builds before pumping the gas to get them to fire. Obviously can't do that here. Is there something I can unhook to keep it from firing while I crank it over and then just plug back in?
What do you guys do?
Thanks again.
01Steeda
732
Baton Rouge, LA
Apr 21, 2007
  • Apr 21, 2007
I would definatly change the oil and then disconnect the plug to the injectors. then you can crank it over for a minute before starting it.
trinity_gt
3,125
81
99
Canada
Apr 21, 2007
  • Apr 21, 2007
I've found that Ford did a good job with the clear-flood mode: simply floor the throttle, then start cranking and it won't inject fuel and thus won't start. Allows you to spin it on the starter before firing it up.
I do this after an oil and filter change: floor the throttle, crank it for about 10-seconds or so to get some oil back in the pump and then release the throttle and it fires right up, without all the typical bearing noises.
After 6 months of storage you shouldn't really have any issues. I'd also change the oil and burn through as much of the gas in the tank before filling it with fresh stuff. Did you put a fuel stabilizer in the tank before storing it? If not, you might want to put a can or two of injector cleaner in the first fresh tank...
01Steeda
732
Baton Rouge, LA
Apr 21, 2007
  • Apr 21, 2007
really?
My car has always started floored or not.
trinity_gt
3,125
81
99
Canada
Apr 21, 2007
  • Apr 21, 2007
Weird. I can consistently mash the gas, turn the key and it will not start. If I'm still cranking and release the gas, it fires right up.
Mine's an 02 GT with what I believe is an MDE2-based tune. Might be MDE3 but I'm pretty sure it's MDE2. Maybe that's the difference.
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
