Starting engine with no transmission?
  • Thread starter Thread starter Boss 351
  • Start date Start date Jun 12, 2004
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Jun 12, 2004
  • Jun 12, 2004
Do you think it would kill anything? Only the flywheel is on the engine and it's supported with the stock supports and a rope so the engine won't drop. I need to finish the project and get the engine running but I don't have a manual flywheel yet and the clutch isn't here yet... Not that I'd rev the piss out of it, just to get it going a little.
85GTlover
704
  • Jun 12, 2004
I do not see a problem doing that, it has been done many times before and it is done to motorcycle engines all the time, your situation is a little different but it should be possible and I cannot see what would cause any damage.
jadedinpa
1,094
lancaster, pa
Jun 12, 2004
  • Jun 12, 2004
yeah it's fine- too bad ford mounted the starter on the bell housing instead of the block...
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jun 12, 2004
  • Jun 12, 2004
Well, I'm never short of a different opinion -- I'd wait. The engine makes a heck of a lot of torque, and it's designed to be constrained by the motor mounts AND the tranny mount in back. I'd want something a lot more secure than a rope -- so it's not just hanging off the front mounts. Be patient - you're almost there.
Curious though - how are you gonna mount the starter with no bell housing or crank it with no flywheel? And you wouldn't want to run it with no flywheel anyhow.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jun 12, 2004
  • Jun 12, 2004
I was thinking the same thing.
Mustang5L5
Mod Dude
Feb 18, 2001
43,335
18,062
224
Massachusetts
Jun 12, 2004
  • Jun 12, 2004
You at least need a flywheel mounted as the engine uses the energy stored in it to carry the pistons through it's paces.
squeeeg
1,905
Michigan
Jun 12, 2004
  • Jun 12, 2004
he was saying that the flywheel is mounted on the engine so that isn't a problem. But you do need the tranny in place, you have to have the tranny mount to keep the engine from moving too much.
saleenx029
117
Cincinnati, Ohio
Jun 12, 2004
  • Jun 12, 2004
I was faced with this scenario and decided NO, it will be too unstable and could invite catastrophy. Just my opinion.
stephen4785
321
Fort Worth Texas
Jun 12, 2004
  • Jun 12, 2004
my 2 cents-if youve got the front of the motor supported well then it should be fine.I wrok on big rigs and when we do a clutch job we replace the rear main seal to make sure it doesnt leak we bolt the flywheel on and run it for 30 minutes.You cant rev them up or anything.The only thing that suports them in the back while you do this is a bottle jack on some 4x4.If youve got it out of the car then just be sure the front is supported very well.I might also add that big rigs have 3 engine mounts.1 in the front and 2 on the side either on the bellhousing or on the block.
I had a buddy that started up his motor on and engine stand without a flywheel.He said it worked fine untill he rev it up and it fell over forwards and hit the ground.Didnt hurt anything though.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jun 12, 2004
#10
  • Jun 12, 2004
  • #10
No, you don't need the transmission bolted in place, but I'd be interested to see where/how he'd mount the starter without the bell houseing?
87'GTstang
1,025
#11
  • Jun 12, 2004
  • #11
Yeeep.............
Besides there is a reason as to why the flywheel MUST be attatched to the engine to make it run properly. It is not just there to turn the engine via starter over but is a momentous force which while having all that mass of the flywhell spinning, it also helps keep the engine turning over and over and over - Don't do it.
TT91
1,536
Paramus, NJ
Jun 12, 2004
#12
  • Jun 12, 2004
  • #12
maybe he is going to hold the starter on the flyhwheel and tell his buddie to "CRANK IT!".....
Boss 351
Jul 13, 2003
2,433
23
48
Canada
Jun 14, 2004
#13
  • Jun 14, 2004
  • #13
Flywheel is on... As for the starter I am king of bracketery and duct tape so don't doubt my skillz
But I didn't have time to do anything this weekend so I'll wait... I hate waiting though, I have doubts that the engine will run fine since I got a used carb and didn't rebuild it.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jun 14, 2004
#14
  • Jun 14, 2004
  • #14
While waiting for the rest of your parts, I suggest you aim your bracketry and duct tape skillz at rebuilding the carb.
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
