Starting issue
  • Thread starter Thread starter coolblue65
  • Start date Start date Jul 2, 2007
coolblue65
1,224
Algonquin, IL
Jul 2, 2007
  • Jul 2, 2007
I went to go for a ride yesterday morning and when I went to start the car I could hear the starter spinning, but it was not cranking the engine. This is a new problem, the starter is pretty much the only thing I did not replace when I put in my 347.
But I am not sure if the problem is the starter or the the box on the fendor.
So what are everyones thoughts?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 2, 2007
  • Jul 2, 2007
If the starter is spinning but not cranking the motor then the starter motor relay should still be good. Just to make sure, have a buddy crank the car while you check the voltage out of the relay with a multimeter. Otherwise it is most likely a problem with the starter.
iskwezm
4,159
20
79
Rowland Heights,California
Jul 2, 2007
  • Jul 2, 2007
sounds like the actuator in the motor isnt kicking the gear out, probably just replace the starter.
garystocker
305
New Jersey
Jul 2, 2007
  • Jul 2, 2007
agreed!
xoxbxfx
3,959
Southlake, TX
Jul 2, 2007
  • Jul 2, 2007
I agree...replace the starter...you could try banging on it with a mallet to see if it helps, but you will probably need to replace it in the end.
coolblue65
1,224
Algonquin, IL
Jul 2, 2007
  • Jul 2, 2007
Since it seems unanimous, I am looking at these two starters, and I am having trouble deciding which one is the right one for me, considering my car was a 289 with a 3-speed manual, then I switched to the 5-speed, then I put in the late model 347 with the 5-speed, and the whole time I was using the same starter.
So what is the difference between these two??
Starter - Ford Mini for 289-302-351W/C AT & 5-speed M/T
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_413331_-1
Starter - Ford Mini for 289-302-351W/C 3 & 4-speed M/T ONLY
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_413332_-1
garystocker
305
New Jersey
Jul 2, 2007
  • Jul 2, 2007
Why mini? Get a rebuilt unit in a FORD housing, or get yours rebuilt.
coolblue65
1,224
Algonquin, IL
Jul 2, 2007
  • Jul 2, 2007
Because, I have long tube headers and the big starter is really tight which makes it a pain to get in and out and prone to heat soak, plus my car is lowered in the front so the steering linkage will some times give a love tap to the starter. Lastly, I can't tell you how many 'rebuilt' starters I have put in my stang over the years. I am amazed this one has lasted as long as it has - which is probably only because I have barely driven it in the last 2 years!!)
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 3, 2007
  • Jul 3, 2007
Because mini-starters are AWESOME. Ford switched to a mini-starter design in the 90s. They are more efficient. They put out more crank power with less battery draw and they are lighter wieght. Its straight up win/win.
iskwezm
4,159
20
79
Jul 3, 2007
#10
  • Jul 3, 2007
  • #10
I used to have the same problem and went through a few starters.I finally got a "cheap" one from Kragens and has been on the car for about 7 years now, no problems with heat soak and long tubes either. i think its just luck of the draw when buying a rebuilt starter.
coolblue65
1,224
Algonquin, IL
Jul 3, 2007
#11
  • Jul 3, 2007
  • #11
so can anyone tell me what the difference between those two starters i posted is? I can't seem to find a solid answer.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 3, 2007
#12
  • Jul 3, 2007
  • #12
One of them is for 157 tooth flywheel any the other is for a 164 tooth flywheel. What trans do you have in your car ?
coolblue65
1,224
Algonquin, IL
Jul 3, 2007
#13
  • Jul 3, 2007
  • #13
Thats what I figured but it doesn't seem to say which is which.
I have a Tremec 3550 and a 157 tooth flywheel.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 3, 2007
#14
  • Jul 3, 2007
  • #14
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
A
No crank no start 4.6l
  • Alfredosp
  • May 4, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 4, 2026
Alfredosp
A
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Saturday at 9:08 AM
SchwarzStock
