Starting issue
coolblue65
1,224
Algonquin, IL
I went to go for a ride yesterday morning and when I went to start the car I could hear the starter spinning, but it was not cranking the engine. This is a new problem, the starter is pretty much the only thing I did not replace when I put in my 347.
But I am not sure if the problem is the starter or the the box on the fendor.
So what are everyones thoughts?
If the starter is spinning but not cranking the motor then the starter motor relay should still be good. Just to make sure, have a buddy crank the car while you check the voltage out of the relay with a multimeter. Otherwise it is most likely a problem with the starter.
Since it seems unanimous, I am looking at these two starters, and I am having trouble deciding which one is the right one for me, considering my car was a 289 with a 3-speed manual, then I switched to the 5-speed, then I put in the late model 347 with the 5-speed, and the whole time I was using the same starter.
So what is the difference between these two??
Starter - Ford Mini for 289-302-351W/C AT & 5-speed M/T
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_413331_-1
Starter - Ford Mini for 289-302-351W/C 3 & 4-speed M/T ONLY
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_413332_-1
Why mini? Get a rebuilt unit in a FORD housing, or get yours rebuilt.
Because, I have long tube headers and the big starter is really tight which makes it a pain to get in and out and prone to heat soak, plus my car is lowered in the front so the steering linkage will some times give a love tap to the starter. Lastly, I can't tell you how many 'rebuilt' starters I have put in my stang over the years. I am amazed this one has lasted as long as it has - which is probably only because I have barely driven it in the last 2 years!!)
I used to have the same problem and went through a few starters.I finally got a "cheap" one from Kragens and has been on the car for about 7 years now, no problems with heat soak and long tubes either. i think its just luck of the draw when buying a rebuilt starter.
