starting my diy intercooler install
stanggt00
371
baltimore md
ok guys for all you do-it -yourself-ers
i am doing this write up for us
this will be and intercooler install with a lot of help from ebay :D
here are some pictures i almost have every thing i need
intercooler from ebay about 150 bucks....
bov about $50 bucks and $20bucks for the pipe
3" pipe kit $120 bucks
crappy rubber will replace this with better ones
another picture of the parts
dam guys sry about the size of the pictures
once i get the hoses, new better connectors, new clamps t-bolt type a must for the high compression side of the blower and anything else i find i will need i will post it
i will also take a few shots of my car and blower
also if there is any work i cant do myself like if welding is needed or some thing i will get prices and part numbers
thxs guys
well from what i understand a blow off valve is almost if not the same as a bypass valve only difference is bypass vents back into the intake and not the air
i will route the air back into the intake just before the blower so that the maf readings are not thrown off
i think if i want to vent to the air i have to put the maf after the blower and the bov and i think i need a differ. type of maf, a flow through type
i think not to sure on that
and cool more good info thxs saleenGt :flag:
blck96svt said:
very nice ! im excited to see updated pics, does anyone have pics or know where pics are of a intercooler set up on a s281 saleen front fascia, greatly appreciated :SNSign:
i can help on this one too. heres how it looks:D
hey saleen do you have any picture of the layout for your pipping ...
if you dont want to post them then pm me i am looking at the car a trying to get an idea how i want to run the pipping since i will be doing the install solo
i know the shortest route will reduce the boost lost but it must also be a good fit.
and once again thxs a lot for that front shot of the car with the bumper off that helps a lot :nice:
i really want to put in a custom FMIC this winter, so im subscribing.
BTW - whatever you do stay away from hightempsilicone.com - they take FOREVER to ship!!!
and coudl you give me the specs on that intercooler?(saleenGT2001 & stanggt00)
the intercooler i have is 31X12X4 with 3"in and out let got it from ebay for 160.00
i was on modularpower house and tim was saying to help from having to cut on the bumper you may want to get a shorter cooler
maybe 31x6x4 or something like that
Looks like the same one I built except I used a different IC with the inlets on the bottom. Did I advise you? People pm me all the time. I upgraded the silicone elbows and the clamps and also used a upgraded bosch bypass with a 15 lb spring. so I use 2. One of the springs in the greddy bypass needs to be removed there is a large one and a small one leave the small one.If it losses boost replace with the larger one.If not it won't open right and you get compressor surge. I also bought my clamps and elbows from www.siliconeintakes.com
