starting problem + daily driver = HELP!!!
  • Thread starter Thread starter mxmattd
  • Start date Start date Apr 8, 2005
M
mxmattd
73
Orange County, California
Apr 8, 2005
  • Apr 8, 2005
When I turn the key, all I hear is the clicking from the solenoid. I bypassed the solenoid, and the starter turns a couple times VERY slowly and then stops. Here are the things I have checked today...
Battery - Fully charged, 13.1 volts, holding its charge fine
Starter - Bench tested, worked perfectly
Battery cables - New condition, no corrosion on terminals
Solenoid to starter cable - same as above
What am I missing here?
Jester67
908
TN
Apr 8, 2005
  • Apr 8, 2005
You might wont to have the battery checked any way they can have the correct voltage but not give the cranking amps needed.
65fastback2+2
1,229
Louisville, KY
Apr 8, 2005
  • Apr 8, 2005
sounds like a battery to me, which means a possible alternator problem as well
M
mxmattd
73
Apr 8, 2005
  • Apr 8, 2005
How can I test the amps? I have a digital multimeter that reads up to 200mA, can I use this? Or can I just take it into Autozone and have them test it?
Jester67
908
TN
Apr 8, 2005
  • Apr 8, 2005
Take it to the zone and have it load tested that is the only to do it.
2nd Mustang
2,488
Southern California
Apr 8, 2005
  • Apr 8, 2005
If you use a multimeter, it better read in amps, not mA or you'll fry it.
Jonstantine
487
Oklahoma
Apr 9, 2005
  • Apr 9, 2005
if everything else is good, id replace the solenoid
although ive had success with several different parts interchange when hearing solenoid noises
TampaStang
67
Tampa, FL
Apr 9, 2005
  • Apr 9, 2005
usually battery though when that happens...
Have someone jump you, if it starts right up, probably battery..
geostang351
946
Danb., CT
Apr 9, 2005
  • Apr 9, 2005
You bypassed selenoid and you said it cranked slowly. Definitely the battery
M
mxmattd
73
Apr 9, 2005
#10
  • Apr 9, 2005
  • #10
Thanks for the info guys. I just assumed the battery was fine when it charged and tested at the right voltage. Anyway, I took the battery to Pepboys, they tested it, and it had a bad cell. So I got my free replacement, put it in, and no more problems! I probably tested everything else in the starting system. Oh well, at least I learned some things.
Jester67
908
TN
Apr 9, 2005
#11
  • Apr 9, 2005
  • #11
Good deal.
F
Alternator Not Charging
  • Fri Guy
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2025
AeroCoupe
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
G
Resolved Please help! (starting issue)
  • Ghoste
  • May 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2025
Ghoste
G
Another no start thread.. pls help
  • Sarah84eyedfox
  • Apr 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2025
AeroCoupe
Old Ford Classic Problem
  • Potomus Pete
  • Aug 31, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 8, 2024
General karthief
