starting problems
  • Thread starter Thread starter SonicCoupe
  • Start date Start date Jun 19, 2005
SonicCoupe
  • Jun 19, 2005
Okay this one is interesting...
When I start my 87 LX Coupe 5.0 it will turn over but the starter keeps spinning like its still trying to start the car. I can take the key out of the ignition and it still keeps going until I pull the battery cable.
Now I just got this Mustang yesterday and today I have replaced the starter, starter relay, and the ignition switch. After I did all that I was able to start the car, turn it off then start it again and drive home. I got home turned off the car then tried to restart it and I am once again having the same problem.
Any suggestions would be greatly appreciated at this point.
2.3l driver
25
  • Jun 19, 2005
i remeber when i had a 2.3l it did that.When the problem was fixed my mechanic told me it was an electrical problem and its not the starter. I will talk to my mechanic tomorrow and find out what the problem is.
SonicCoupe
  • Jun 19, 2005
Thanks! I'd really appreciate any help you could give. Just let me know.
jadedinpa
1,094
lancaster, pa
Jun 19, 2005
  • Jun 19, 2005
when my car did that, it was the starter relay on the fender. did you replace it with a new one or a used/rebuilt one?
SonicCoupe
  • Jun 19, 2005
I replaced the starter relay with a brand new unit from Pep Boys.
HISSIN50
34
129
Jun 19, 2005
  • Jun 19, 2005
WHen this happens, what happens if you remove the slide-on connector on the top of the starter solenoid? If the starter stops cranking, you have a hung-up starter interlock circuit (i would head to the ignition switch and look for burned wires/connections).
If the starter keeps on going, that suggests the solenoid is indeed bad.
Good luck.
SonicCoupe
  • Jun 19, 2005
Good luck.
Well I am guessing it may be the wires then because the solenoid is brand new.
Any idea as to where I can get a new set of wires or is that all part of the engine harness?
HISSIN50
34
129
Jun 19, 2005
  • Jun 19, 2005
I would not make that assumption - many a person has gotten a bad solenoid right out of the box.
One could run new wire by hand for the starter interlock, but I would want to know the solenoid is not at fault.
If you disconnect the slide-on wire and put a test light on it, it should show 12 volts only while cranking. If that happens, that suggests all that wiring is fine.
Good luck.
SonicCoupe
  • Jun 19, 2005
Good luck.
Thanks I'll check that tomorrow
2.3l driver
25
#10
  • Jun 20, 2005
  • #10
i just talked to my mechanic he said its the starter solenoid.
HISSIN50
34
129
Jun 20, 2005
#11
  • Jun 20, 2005
  • #11
That does not surprise me. Many a folk has gotten a bad one right out of the box.
Good luck.
SonicCoupe
#12
  • Jun 20, 2005
  • #12
Good luck.
Yeah I am thinking this also...I'm going to yank the starter off tomorrow and replace it under the 1 year warranty that I have on the one I bought yesterday.
HISSIN50
34
129
Jun 20, 2005
#13
  • Jun 20, 2005
  • #13
Wait, is it the starter or starter solenoid which the mechanic believes is at fault?
Good luck.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
  • Mindseye007
  • Aug 16, 2026
Mindseye007
