The car sat in storage for 9 monthes, brought it out fired up like a champ. Then after that once it gets hot it doesnt like to start.
I replaced the batt, starter, and starter solinoid.
And trouble shot this much....batt reads 12.66V, Starter solinoid reads 12.66Vs ( Trunk Mounted Battery). Once you hit the key they both drop to around 7Vs. Batt posts and cables get warm. and
It'll turn over once then pause, turn over, pause, etc etc...and MAYBE fire.
let it sit for about 2 hrs and cool off and it'll turn over slow then start.
Let it set over night and fires right up in the AM....
before i go replacing my power wire from the trunk to the solinoid do you think this may be the problem, a bad spot in the wire?!
. if cable is heating up then there is too much resistance somewhere in that circuit, and that is not a good thing. For instance, the negative battery cable will heat up and smoke if there is a bad ground and you try to crank the engine. I had this problem (except my battery is still under the hood), and it turned out to be bad grounds. I would guess that there is a bad connection somewhere or you need thicker gauge wire since your battery is way back in the trunk. The resistance over a wire increases when it gets longer.
