Starts, dies-starts, dies- help!!
87TTopGT
173
Went out today to start my Stang, immediately cranked as usual, ran 1/2 second and died. Did this four times, fifth time stayed running. Did the same after I parked it, and later came out to start it. Anyone had this happen before, or know what causes it? Any help would be appreciated... :shrug:
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) Coil
B.) TFI module
C.) PIP sensor in distributor
D.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
E.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires
F.) Ignition switch - look for 12 volts at the fuel injector red wires
G.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
If it starts then, you have a fuel management issue. Continue the checklist with emphasis of fuel related items that follow. If it doesn’t ,then it is a computer or timing issue: see Step 4.
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off only likely if the engine has been worked on recently).
jrichker- DAMN! THAT was a post. Thanks for the info, that is going into my archives. Actually, it cranked and started , THEN died. Then the fifth time it fired right up like normal and ran fine.
Quick5pnt0- tried holding accelerator down, made no difference when it died.
Any other ideas? :shrug:
sounds like your fuel pressure is bleeding off after sitting for a while - things wear out like that. Check your fuel return system.... Couldn't hurt to have clean injectors (1 can of BG fuel treatement should do it) available at good mechanic shops not chain auto stores
I had the same problem about a month ago, it would start then immediatly die, but would eventually stay running. I replaced the ignition switch and the lock cylinder in the steering column and that fixed the problem. I only spent $20 on both parts. Cheap fix.
I had the same symtoms you describe on my 86. It was the controller on the distributor (I forget it's name). That little card/chip thingy that controls the dwell. It's attatched directly tot he distributor on my car though I've heard it was relocated to another location on later models.
That's the first thing I would check...Mustangs are notorious for that.
i have this problem too and a couple of people have told me its probably the fuel filter... then again its carburated and i've never changed it in the 14 months of owning the car... but should i do the ignition switch and lock cylinder first?
