Starts with starter fluid then dies
  • Thread starter Thread starter K1tha1
  • Start date Start date Oct 28, 2024
First Prev 2 of 2
AeroCoupe
6,092
4,186
183
Claremore, OK
Oct 28, 2024
#21
  • Oct 28, 2024
  • #21
Okay, then you did not hear the pump come on when you turned the key on as it required the engine to be running for it work. On the factory carbureted cars there is no inertia switch so it does not factor into this situation.
I would suspect the fuel pump, plugged or pinched line between the fuel pump and the tank, and/or the sock filter in the tank is covered with debris and plugged. It would not surprise me if there was not a sock filter in the pump as some people remove them and never replace them. This is not smart but people still do it.
Reactions: K1tha1 and limp
K1tha1
23
Somewhere thinking about Arizona
Oct 28, 2024
#22
  • Oct 28, 2024
  • #22
Thank you
First Prev 2 of 2
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
