Steed pullies vs. cnl upper plenum
  • Sponsors(?)
twogts4us
4,188
11
79
54
Dunedin, FL
It would be close, based on the claims of the manufacturers. The plenum with the OEM TB is worth about 5 rhwp and probably about the same for the pulleys. Plenum is a heck of alot easier to install though, and doesn't require an air wrench (pulley swap does). So there's my 2 cents - plenum! Check www.modulardepot.com - and see their plenum shootout, parts 1 and 2...good stuff!
twogts4us
4,188
11
79
54
Dunedin, FL
JonJon said:
pulleys are way cheaper
Yeah but plenum is a 15 minute swap. And with a TB, I think the gains would be greater. The newer GTs' pulleys are optimized for power more than ever, and there are still some gains to be had - but not as much as on the ol' 5.0.
Thread starter Similar threads Forum Replies Date
W Cheapest place to buy steed pullies SN95 4.6L Mustang Tech 4
R For Sale Steeds Cold Air Intake Cheap Engine and Power Adder 1
H Steeds Vs Bama 1996 - 2004 SN95 Mustang -General/Talk- 9
-Tomcat- Hi Everyone! Meet My Faithful Steed - Sid. The Welcome Wagon 5
F steed front sway mount billet Suspension Parts 6
J Expired Mega Bite Lower Steed Uppers Suspension Parts 11
R 2006 Supercharged Mustang GT with Steed Mods S197 Mustangs For Sale (2005-14) 0
txredgt Wanting to lower the steed 1996 - 2004 SN95 Mustang -General/Talk- 8
jcp123 Anybody bother to record MPG on their steeds? 1965 - 1973 Classic Mustangs -General/Talk- 24
Dreadnaught Finally join the steed ranks 2005 - 2014 S-197 Mustang -General/Talk- 4
trailblz WILD steed at SEMA 1996 - 2004 SN95 Mustang -General/Talk- 13
0 The Steed is Getting BLOWN!!!! 1996 - 2004 SN95 Mustang -General/Talk- 29
G Steed sport Springs? SN95 4.6L Mustang Tech 5
3 Put a Bullit in my Steed (stumped) Fox 5.0 Mustang Tech 1
B Engine 2000 GT unknown maf computer and underdrive pulley. SN95 4.6L Mustang Tech 2
7991LXnSHO Fox Under Drive Pulleys 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
FastDriver Fox Fox Body W/ Cai, Ud Pullies, & 4.30 Gears At The Track 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
FastDriver Engine Asp Pullies Do Cause Overheating Issues Fox 5.0 Mustang Tech 11
Taino Tension Pully Issue ???? Fox 5.0 Mustang Tech 13
mikestang63 Installed the U/D pullies and Taurus efan with FAL controller- Need a lil help Fox 5.0 Mustang Tech 21
B Expired Wtb: Stock Pullies, Tensioner, And Brackets Fox Body Mustangs For Sale (1979-93) 0
s0lidllama Crank Turns Other Pullies Wont Fox 5.0 Mustang Tech 2
bchampion '68 Sanden Idler Pully Adapter Classic Mustang Specific Tech 2
O under drive pully question Fox 5.0 Mustang Tech 6
sneaky98gt FS: Steeda Underdrive Pullies (Like New!!!) Engine and Power Adder Parts 3
Nightfire Pullies 101 1996 - 2004 SN95 Mustang -General/Talk- 13
tims 86 a/c delete..underdrive pullys Fox 5.0 Mustang Tech 7
N what are under drive pullies? Fox 5.0 Mustang Tech 18
MY 85 GT Underdrive pullies with a supercharger? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
M my underdrive pullys look like crap!? 1996 - 2004 SN95 Mustang -General/Talk- 3
SableSal FS: ASP Underdrive Pullies 94-95 Engine and Power Adder Parts 0
B procharger pulley pullies Engine and Power Adder 0
juiced_94gt What size belt for stock pullies with underdrive crank pullie only? 1994 - 1995 Specific Tech 0
D Pully's or Gears 2005 - 2009 Specific Tech 7
C need help with idler pully locations Fox 5.0 Mustang Tech 1
S ANyone run an elec water pump and bypass the pully? SN95 4.6L Mustang Tech 9
C FS. March SFI underdrive pullies Engine and Power Adder Parts 1
F Need a belt and pully diagram! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
R Preferred Underdrive Pullies? SN95 4.6L Mustang Tech 55
RyanSG Fluid Dampener, 28.0Oz Imbalance, Black, 4 Crank Pully Bolts, SFI Approved! Engine and Power Adder 0
russ1979 will 94 cobra pullys fit 88? w/link Fox 5.0 Mustang Tech 1
bigsexxy422 pully question Fox 5.0 Mustang Tech 2
B Wobbly Pully Fox 5.0 Mustang Tech 3
7upstang91 Replaced the Underdrive pullies, now noise... Fox 5.0 Mustang Tech 8
SMOKEDYA Under drive pullies Fox 5.0 Mustang Tech 11
9 trick flow underdrive pullies Engine and Power Adder Parts 1
9 New trick flow underdrive pullies Drivetrain Parts 0
F Pully for 3G alt swap Classic Mustang Specific Tech 5
hotstang_46 Need diff pully when adding intercooler? SN95 4.6L Mustang Tech 3
M 1993 mustang pully ??? 1994 - 1995 Specific Tech 0
