  • SN95 4.6L Mustang Tech
Steeda billit window switch install
  • Thread starter Thread starter Bob H
  • Start date Start date Mar 29, 2004
Bob H
49
Central Ohio
Mar 29, 2004
  • Mar 29, 2004
Has anyone done this and how do you remove the old switches (or buttons)?
Thought I'd ask before getting into another easy install that turns into a nightmare.
neoclasiccl
3,043
Help I can't see !!!!!!
Mar 29, 2004
  • Mar 29, 2004
Very easy to do. To do it without scratching the plastic panel I took that off and unbolted the switches from the panel. Then you just pop off the switches since they just snap in. Then install the new ones and bolt the switches back to the panel and reinstall it.
J
jenn*jenn
FL
Jan 16, 2006
  • Jan 16, 2006
just push the plastic buttons down on one side, insert a flat-head screwdriver on the other and they pry right off. Just push the new ones on.
the only button I had a problem with was the directional button for my power mirrors (up, down, left right). the hole in the button does not match the shape of the pin it's supposed to fit over. Its not as bad as a square hole and a round pin -- its a square pin with a point or pyramid at the top and the hole in the button is drilled for a square pin with a flat (not pointed) top. Anyone else have this issue??
I could fix the pin or button to make it fit, but I was under the assumption these buttons were plug&play, not a "custom" install.
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
  • dan50
  • Jul 18, 2026
dan50
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
W
Power Windows Not Working at all
  • Wreckchaser92
  • Nov 24, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2024
89notchDude
