  • SN95 4.6L Mustang Tech
steeda caster camber plate problems
  • Thread starter Thread starter Tarp
  • Start date Start date Feb 3, 2004
T
Tarp
56
Austin Tx
Feb 3, 2004
  • Feb 3, 2004
hello everyone I am a new member and I am looking for a little help.
I have steeda 4 bolt cc's on my car and I get this bad "klunking" noise which is the best way I can describe it. it occurs when I hit bumps in the road and it sounds so bad, has anyone had anything similiar and if so what did you do to fix it??
Thanks for any help!
W
Wes28376
121
Fayetteville, NC
Feb 3, 2004
  • Feb 3, 2004
You might want to double check that your struts are properly seated in the CC plate and that the nut on top of the shock is tight enough. Something similar happend to me. I jacked the car up and and noticed there was play between the top of the strut and the bottom of the CC Plate. Hope this helps.
D
dlsdj
121
Corpus Christi, TX
Feb 4, 2004
  • Feb 4, 2004
Had the same problem
I had a set of the CC Plates on my 03 GT and returned them after a few months. The noise was driving me crazy same as you discribed. Maximum Motorsport has the best from everything I've read, I however re-installed the stock plates and had the alignment shop set it up to Steeda specs. No problem with tire wear but I rotate every 3000 miles.
T
Tarp
56
Austin Tx
Feb 4, 2004
  • Feb 4, 2004
thanks for the help if anyone else has any info please fill me in thanks again
dew22
Banned by Troll
Jan 16, 2003
Tampa
Feb 4, 2004
  • Feb 4, 2004
I just had maximum motorsports cc plates installed no problems. I think there is something else wrong here I have driven and been a passenger in numerous cars with cc plates and never heard "clunking" sometimes a little more road noise but that clunk you described sounds like an incorect install or another problem.
C
claytucc3
825
Santa Clarita, Ca
Feb 4, 2004
  • Feb 4, 2004
Your strut may be bottoming out. What setting did you use when installed the strut spacers.
KStrike155
364
Danbury, Connecticut
Feb 10, 2004
  • Feb 10, 2004
I also have this problem. I used the stock struts with Steeda Sport lowering springs. I used the setup with one bearing underneath the plate and two one top. It is to be used with stock struts and up to a 1.5" drop.
I have heard that it could be because the bolt on top is not tight... I just installed these yesterday and they were fine then (at least I didn't notice then) but today they clunk. Could it just be the springs setting-in?
K
Ken01GTvert
175
Colorado
Feb 10, 2004
  • Feb 10, 2004
You might want to check underneath the c/c plate to ensure you don't have any extra space underneath it and the top on the strut. When I installed my c/c plates I had the top of the strut get caught on the edge of the c/c plate. It seemed like it was firmly seated with threads out of the top of the c/c plate to put the large nut on. However, when I reached my hand up underneath the fender, under the c/c plate I found that there was about 1/2" of space. I had to loosen up the adjustment bolts on the c/c plate and then wiggle it a little while jacking up from underneath the strut which got things to seat 100% at which point I tightened the nut on top. I would think that if things weren't seated properly that you could wind up getting the clunking noise.
K
Ken01GTvert
175
Colorado
Feb 10, 2004
  • Feb 10, 2004
Oops, I just said the same exact thing that Wes said. Sorry about that. Another thing to check is the dampener on your strut. Are you using the stock struts or something else?
K
KobraKomander
63
#10
  • Jul 5, 2004
  • #10
thanks for the info guys... solved my cc problems.
StangLou
1,264
Holly Springs, NC
Jul 5, 2004
#11
  • Jul 5, 2004
  • #11
Was that what was wrong with yours? There was something just not seated right so it had play in it, hence the clunking? I got steeda c/c plates installed the other weeks with my springs and I have the same clunking sound. Only happens when Im backing up slowly or going forward slowly. I also on hear it from the left front. Could this be the same thing Ive got the day off tomorrow so Ill hunt to see if I see any slack.
StangLou
1,264
Holly Springs, NC
Jul 5, 2004
#12
  • Jul 5, 2004
  • #12
Just jacked my car up on both sides and felt around the strut to see if I felt a gap. To me both sides feel equal They both do however feel like they are kinda tilted. Say your looking dead at the car....
the lt side feels like this \ / is what the rt side feels like
Its no where near that sharp of a slant, but its to give you an idea. I had a full alignment done after the install, wouldnt they have noticed if it wasnt seated correctly? Should it be 100% flush?
Not trying to hijack the thread, just trying to figure out what the heck is making that annoying clunking sound Glad its not just me!!!
mransr
1,188
36
98
Riverside, SoCal
Jul 5, 2004
#13
  • Jul 5, 2004
  • #13
I chased that 'clunk' for months...I finally took the C/C plate (Steeda 3-bolt) off and re-assemebled and the strut off the car to make sure everything was seating correctly...it turned out the C/C plate's ball joint has a little up and down slop/play in it...(only the right side one, the left is real snug)...
I'm looking to replace the Steeda plates with ones with a rubber or urethane upper mount to quiet and maybe smooth the ride some...
StangLou
1,264
Holly Springs, NC
Jul 7, 2004
#14
  • Jul 7, 2004
  • #14
Well after looking at the car more closely, the strut is flush against the c/c plate. Its just the rubber piece on top is slightly off.
I was actually told mransr's theory the other day. Apparently there is some joint that has a bushing that goes bad with the steeda c/c plates. The bad bushing allows for "play" and metal on metal contact, thus creating our "cluncking" sound. Shop said several guys had sent theirs back to steeda, and steeda just sent them a new one that worked fine. Sounds like this could be our problem
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
  • Gulftown980x
  • Jul 29, 2026
squeak93
Suspension Caster Camber Main Plate Replacement
  • bleedinggreen
  • Apr 20, 2024
Fox 5.0 Mustang Tech Apr 20, 2024
bleedinggreen
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
