Steeda Caster Camber Plates
cracula69
425
Stamford, CT
Those w/ Steeda's Caster Camber plates that have the spherical bearing installed: Do you notice that they are incredibly loud when you hit a bump? ie: noise is translated directly thru the spring/strut to the strut tower (spherical bearing).
I'm planning on dumping mine for P-S-T's C/C plates. They have polygraphite (self-lubricating) bushings that are pretty stiff but have SOME give.
Dave
Yeah I would check that top nut on the strut tower because the first tim I put mine on they wasn't tight and it made a popping noise. Mine doesn't make any noise. And if the caster camber plates give then your suspension parts are going to give too.
