  • 2005 - 2009 Specific Tech
Steeda Cold Air
  • Thread starter Thread starter red05bullitgt
  • Start date Start date May 30, 2006
red05bullitgt
861
Pittsburgh, PA.
May 30, 2006
  • May 30, 2006
Update, dyno results are now in..For anyone who may be interested, I have the long awaited independent test results, for the Steeda CAI, from Brenspeed..In addition, you'll also notice that Brent performed, a side by side comparison, with the C&L street CAI, and according to the results, both systems were nearly identical in both HP. and Torque numbers..Anyhow, I hope everyone may find the test results, helpful and perhaps useful, in someway... Here are your test results.
C&L Street Intake
300.07 HP/310.28 Torque
Steeda 90mm
297.60 HP/309.7 Torque
The test was performed by making 3 pulls with each air intake. The numbers above are the average of the 3 pulls.
The steeda worked great but fell short above 5,000 rpm’s, most likely due to the lack of aftermarket inlet pipe.
Karen White
Brenspeed
Visit us at www.brenspeed.com
bleedingvayneAD
339
At my computer, duh
May 30, 2006
  • May 30, 2006
...ok....?
Schlitz-420
97
Michigan
May 31, 2006
  • May 31, 2006
C&L Street Intake
Steeda 90mm
Karen White
Brenspeed
Thank you for the info. However i am confused by the numbers posted. This does not appear to be a power gain over stock. Maybe i am wrong but i thought the stock 4.6L created very close to 300HP out of the box. Am I mistaken?
P
Pro Mod
236
Wharton, WV
May 31, 2006
  • May 31, 2006
The numbers quoted above are rear wheel hp/tq #'s
Although a stock Mustang makes 300 hp at the flywheel, it puts down between 265-270 on average at the wheels.
R
RICVA05
66
  • May 31, 2006
Opp's already been answered.
red05bullitgt
861
Pittsburgh, PA.
Jun 1, 2006
  • Jun 1, 2006
As ProMod stated, the Mustang's stock 300HP. is rated at the crank, and not at the rear wheels.. The actual rear wheel HP. is around 265 stock..The numbers that were posted, are rear wheel numbers.. So yes, there is a significant gain over stock..Anyway, it's not that you were mistaken, but seems more like, you were just mis-informed..
ramjetlx
212
Honolulu, Hawaii
Jun 1, 2006
  • Jun 1, 2006
Is this with a chip also or with just the intake itself using the stock program?
red05bullitgt
861
Pittsburgh, PA.
Jun 1, 2006
  • Jun 1, 2006
I'm sure that your well aware, that the C&L and Steeda cold air intakes, do require tuning...Just as you're Tunable Induction CAI, also requires tuning..Therefore, you cannot run the stock program, with these type of intake systems..However, in fairness to both C&L and Steeda, Brenspeed did just a baseline tune, for testing purposes only..Anyway, I hope this provides the answer, you were looking for..
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
Engine '88 GT Has No Power Above 3000 RPM After Trick Flow 11r Heads Install
  • JRerecich
  • Feb 12, 2020
  • 2 3 4
12K
Fox 5.0 Mustang Tech Feb 23, 2020
tinker451
T
Electrical Random Stall Scenario 1992 LX 5.0
  • ppartain
  • Jun 9, 2019
3K
Fox 5.0 Mustang Tech Jun 15, 2019
nickyb
