I was deciding on Steeda LCA's and came across on a decision of steel or aluminum. What's the difference besides the material and the price? Any info would be greatly appreciated.
Weight savings for the hardcore racer. I just don't like it that they paint their aluminum ones.
Aluminum is lighter but more prone to breaking. I went to a shop to have them installed and the shop wouldn't install them. They showed me a set where the weld had broken (which can cause a serious accident on the street or track).
If you hit a big pothole aluminum will be more prone to crack whereas steel will bend before cracking. Thus I ended up with some tubular steel Maximum Motorsports LCA's with spherical bearings on both ends.
What is your reason for replacing the LCA's? Straight line grip? Better handling in the twisties?
I plan on doing 1/4 miles pretty much.I went with the tubular steel set from Maximum Motorsports.
I'm not familiar with them, unless you're referring to J&M Performance which sells on Ebay.
Interesting...I bought my MM lower arms from American Muscle as well. It was cheapest price I could find on the MMs. The J&Ms look very similar in nature to the MMs. What really gets me is your J&Ms are more money than the MMs. The main difference I see is the J&M uses a urethane bushing at both ends. The MM unit utilizes a heim joint at the axle housing and a 3 piece urethane type bushing at the other end. All things being equal???, the J&M would problably be a little more street friendly without the heim joint. Certainly the heim joint would be more effective in the performance area.
Small diff. You'll be fine with either.
I'll be doing these next after I get my o/r X put on
