  • SN95 4.6L Mustang Tech
steeda pullies and adjuster?
  • Thread starter Thread starter 98MACH1R
  • Start date Start date Aug 7, 2005
9
98MACH1R
I wanna put it in so bad, please help.
Jun 6, 2005
131
  • Aug 7, 2005
i have a 98 gt n/a with a few minor things but i want underdrive pullies and timing adjuster so i ordered these from steeda and now my question is how do i use the adjuster i know nothing about timing and how it works but in you guys opinions what would you set the timing at?
fudleyd
180
Littleton, CO
Aug 7, 2005
  • Aug 7, 2005
All you have to do is align the notches on the adjuster and set the screws. Some sources have reported that the adjuster is actually 1 degree off on the negative side (which means if you have it set @13 it might actually be 12 degrees advancement.) What octane gas is available in your area? This will be a critical factor in how much you can advance your timing without detonation. I can only get 91 octane here in Denver and I had the best results with 14 degrees advance with no detonation. Some people advance the timing until they hear detonation and then retard it until it goes away. One good test for this is the drive your car up a hill in fourth gear. There are also a lot of posts on this subject so do a search and you should get all of the info that you need! Good luck!
9
98MACH1R
Jun 6, 2005
131
  • Aug 7, 2005
i can get only 91 octane if i advance it what type of gains will i see with advanced and the steeda pullies?
fudleyd
180
Littleton, CO
Aug 9, 2005
  • Aug 9, 2005
Sent you a PM
Bubba Z.
88
Tallahassee, FL
Aug 9, 2005
  • Aug 9, 2005
You're looking at a 10-15 HP gain with the u/d pullies and the adjuster set at 14 degrees. You'll feel it too.
T
Torinalth
952
Clayton NC
Aug 9, 2005
  • Aug 9, 2005
one thing to note is that the TA while nice for peak HP really makes more power down on the lower end. the lower torque raised is the big thing with the TA. I'm still torn if i want to go TA or just hold out till i need to get a SCT chip and tune the timing in myself...
as far as how to do it I'd raise it one notch at a time going up a hill from around 2krpm to redline and stop advancing when you hear detonation... just like said above. really is the best way.... oh, make sure you have all the 87 octane out of the tank before you ramp it up i'd say your second full tank of 91 would be when i'd find your end point
Torinalth
9
98MACH1R
Jun 6, 2005
131
  • Aug 9, 2005
well thank you guys i know what im going to do now im just gonna buy them tonight
fudleyd
180
Littleton, CO
Aug 10, 2005
  • Aug 10, 2005
Let me know how it works out for ya man! If you have any questions just let me know!
9
98MACH1R
Jun 6, 2005
131
  • Aug 10, 2005
thanks i will
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 19, 2026
squeak93
M
Kind of a unique problem
  • MadMatt7
  • Oct 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 15, 2026
rednotch
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
