GT02MG said:
Even if its not a vette what a sick car
Still don't know the price, but I'd like to see how it compares to the Saleen Extreme Mustang.
Here's some info on the Q 525:
"Steeda Autosports
Introduces
2006 Supercharged Steeda Q 525
Steeda Autosports introduces the 2006 Supercharged Steeda Q 525. The new model of which a limited number will be built, is the top of the line Steeda Q for the customer who demands the ultimate in performance and drivability. The engineers at Steeda Autosports have paid careful attention to vehicle dynamics to give the Q 525 world class ride and handling.
One looks tells you this is a serious performance car, with its new for 2006 light weight, competition front facia equipped with functional brake cooling ducts. These ducts feed cool air to the 14” Steeda front brakes of the Q 525. At the rear the new Steeda designed, engineered and manufactured rear sway bar with billet end links improves handling and rear compliance.
Power and Performance
The heart of the Q 525 is a Magna Charger 5th Generation MP112 hybrid roots style supercharger with internal bypass valve. The supercharger provides instantantanious boost from 1,200 to 6,000 rpm. The unique valve is responsible in eliminating parasitic drag from the crank shaft to the supercharger.
The Eaton internal rotating assembly components are durability tested to OEM standards and are accepted by Ford Motor Company. The same assembly as used in the Cobra, Lightning and Jaguar XJR.
Working with Magnuson Products, Steeda engineers created an intercooled system as well as a specific tune for the Q 525, resulting in a very impressive 500 horsepower with 530 ft. lbs torque.
Suspension
The suspension dynamics of the Q525 are in keeping with the Steeda Autosports tradition of designing, engineering and manufacturing quality suspension systems that are competition proven. In addition, they are constructed to strict Steeda quality standards and are precision engineered for both improved ride quality and the finest street and track performance.
2006 Steeda Q 525
Specifications
Engine
5.0 liter Modular
Steeda/Magna Charger supercharger system with intercooler
62 mm twin -bore throttle body
Steeda/SCT air meter
8.5:1 compression ratio
500 horsepower @ 5400 RPM
530 ft lbs @ 3650 RPM
Electronic Fuel injection with 60 lbs injectors
Steeda Cold Air Kit
Forged crank shaft
Forged connecting rods
Diamond forged pistons
Steeda axle back exhaust system
Suspension
Steeda Sport Springs
Tokico D-Spec shocks and struts
Steeda camber adjusters
Steeda control arm relocation kit
Steeda bumpsteer kit
Steeda front adjustable endlink kit
Steeda G-Trac brace
Steeda billet strut tower brace
Steed billet lower trailing arms
Steeda rear sway bar and billet end links
Steeda adjustable rear panhard bar with panhard bar brace
Steeda rear shock tower brace
Steeda 3 point frame rail and torque box brace
Brakes
Steeda 14” four piston front brakes
Steeda 13” rear brakes
Wheels and Tires
Steeda Ultralite 06 18 x 9.5 alloy wheels
Goodyear Eagle F1 Supercar 275/40/ZR 18 performance tires
Interior/ Exterior
Steeda competition front facia with functional brake ducting
Steeda full cowl induction hood with hood pins
Steeda rear race wing
Steeda exterior graphics package
Steeda billet rear badge
Tri-Ax Shifter with billet shift handle
Steeda billet pedal cover set
Steeda billet dead pedal
Steeda billet A/C knobs and door handles
Billet speaker covers
Polished billet fuse box covers
Polished billet power steering cover
Polished billet oil cap
Polished billet brake fluid cover
Steeda custom floor mats"
