steeda says yes maximum motorsports said no...
jrc_03_gt
786
www.cardomain.com
This is the question I have. Im puting on the eibach pro-system plus kit on my 03 gt which includes shocks struts springs and front and rear swaybars. Along with MM CC plates. I wanted to change out the rack bushings to get better steering response. So I did not know which ones to get steel offset or steel regular bushings.
Steeda insisted on installing offfset bushings while Maximum motorsports said not to do so, and said offset bushings would create more bumpsteer on a stock k-member. I pulled this info right off mm web page. What do you guys think? check this out.
"There is a myth that the tie rod should be kept parallel to
the ground to avoid bumpsteer. THIS IS NOT TRUE! What
IS required, is that the tie rod be kept parallel to the lower
control arm so that as the suspension moves, the arc of
the ball joint and the arc of the tie rod end do not cause
any steering input to the spindle. As you lower your car,
the tie rod end and the lower control arm move together,
staying parallel. If you install offset rack bushings on a
stock geometry K-member, you are making the tie rod end
and the lower control arm NOT parallel. You will actually
CREATE bumpsteer by installing offset rack bushings on a
stock K-member.
Ford engineers have actually done a very good job at
designing a low level of bumpsteer for daily driven cars.
Specifically, Ford has designed the bumpsteer to toe out
the front wheels under bump. This is a roll understeer
condition; the outside loaded tire will turn to the outside of
a corner as the body rolls. This condition is designed by
Ford by positioning the tie rod end slightly low relative to
the steering rack.
Increasing caster raises the tie rod end relative to the
steering rack. Increasing caster up to half of the
adjustment range with our Caster/Camber Plates will
actually HELP bumpsteer and help performance by
reducing roll understeer. If you increase caster beyond half
of the adjustment range, the bumpsteer curve will shift
toward toe IN under bump, or a roll-oversteer condition. In
this case, it is beneficial to raise the rack, but only by
about 1/10 of an inch. Offset rack bushings raise the rack
far too much. The best solution is to lower the tie rod end
using a bumpsteer kit (MMTR-3,-4). See our test results in
the July 1993 issue of Super Ford for details.
Competition cars using stock K-member geometry will
also benefit from an adjustable tie rod end kit (MMTR-3,-
4). These kits provide an assortment of spacers in .015"
increments to best position a rod end at exactly the
correct height; thus taking into account suspension
geometry tolerances.
Offset rack bushings DO have a purpose and may be
beneficial if you have raised your inner control arm pivots
using an aftermarket K-member. In this case, raising the
rack will help match the geometry of the raised inner
control arm pivots. If you do use offset rack bushings, be
sure to only use aluminum bushings - polyurethane offset
bushings do not work. The urethane has too much “give”,
and therefore it is impossible to get the rack mounting
bolts tight enough to prevent the bushings from rotating
during hard cornering."
I had the Steedas, and while they didn't seem to create a noticable ammount more bumpsteer, they did rotate around in the rack changing the alignment. I switched over to MM Aluminum bushings and couldn't be happier! They are just as quiet (well, quieter, no more creaking rack if the bushings dry out or are improperly torqued) as poly bushings, and I didn't really notice anymore vibration in the steering or car or anything...
Go for MM :D
1LowGT:
The stock steering rack bushings are rubber and can give the steering a vague feeling. You sure can use the aluminum bushings in a stock steering rack! You might have a smidge more road noise but I found no audible difference between the stockers and the aluminum bushings. The steering feel did improve, though.
Chris
well think about it. two completly different companies one sells torque arms the other a five link. both race track proven. its comparing apples to oranges. aluminum wont wear out, what it will do is send stress to a different location in the front end. poly utherane will absorb bumps a bit better but over time will deteriorate. either decision will be a good one. aluminum will be better if you have a good shock and spring package and poly will be good for both a stock or modified setup. food for thought
