  • SN95 4.6L Mustang Tech
Steeda Timing adjuster causing a bucking-surging problem
  • Thread starter Thread starter 4.6modular
  • Start date Start date May 10, 2005
4.6modular
141
Springfield, MO
May 10, 2005
  • May 10, 2005
I've been trying to track a problem down for about 2 years now. at about 1800-2200 rpms with light throttle application the car will surge back and forth very lightly. At WOT or above or below those rpms there is no problem. At times the car will throw codes for the front 02 sensors If I drive aroune those rpms too long. I've been playing with the timing adjuster advancing or retarding timing. When I retard the timing to 12 or 10 which is stock the surging or bucking seems to be solved. Is the computer trying to pull or add timing at those rpms competing with the timing adjuster? Have others had this problem? Is it better to get a custom tune with a chip or ECU flasher?
Thanks.
starchman
73
Sheridan, AR
May 10, 2005
  • May 10, 2005
Sorry, but I have to ask...what octane fuel are you using?
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
May 10, 2005
  • May 10, 2005
Yeah, what octane? This is a known issue with timing adjusters. It is recommended to gradually advance the timing until surging is encountered then back it off until it goes away.
Another thing: Sometimes the timing adjusters are not giving you a "real" value. It is possible to have it set to 12 but it is in reality 15 degrees. Every car is a bit different.
Big Steve
195
Lower Hudson Valley NY
May 10, 2005
  • May 10, 2005
I had 3 5.0's that did the same thing everytime I bumped the timing and ran 93. Basically I just learned to live with it and tried to stay out of that rpm range. Can be real annoying but the performance gain IMO was worth it. Haven't done any timing mods in my 4.6 cause I'm a cheap F and won't buy 93 at 2.49 per.
4.6modular
141
Springfield, MO
May 10, 2005
  • May 10, 2005
I've always used 93 octane.
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
O
Need a hand: Hanging idle with all new parts
  • Overused03
  • May 15, 2024
SN95 4.6L Mustang Tech May 21, 2024
Overused03
O
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
