Steeda Tri-Ax
Check the fluid just in case. I put mine on and I heard the whining, thought it was normal, and turned out my tranny was low on fluid and froze up :damnit:
Now I have a new tranny with new fluid and it doesn't whine nearly as much. Take my advice and check the fluid anyways.
Hef5.0weisen said:
Not sure if the Tri-ax has stops, but maybe they need a bit more adjustment?
Check it out...good luck
Yes, the Tri-Ax does have stops. And if they're out of adjustment, it can make the shifter quite a lot louder than it normally is (not to mention damaging the transmission if they're really out of whack).
Back your stop bolts about a turn back from your shifter being set in gear. (.10) of a inch or so...
The sound your hearing is normal. You have lost the sound deadening between the shifter handle/base so you hear more "metal sounding" harmonics.
I doubt it is your fluid level if the only change you did was the shifter...
Check it anyways for piece of mind:nice:
