Steering Column Bearing Sleeve Replacement
Martman
163
23
28
Louisville, KY
So I have the dreaded steering wheel bounce which makes it feel like the whole column is loose. This is a non-tilt on a 91 GT. I have been told it is the rubber bearing sleeve behind the steering wheel.
Does this sound correct? If so does anyone have any links or can point me somewhere on how to replace this? I have searched google but most of the items are related to replacing the entire column.
https://lmr.com/item/LRS-7993E2/Steering-Column-Tube-Upper-Bearing-Sleeve-Mustang-79-93
Thanks
Yep that's the one. I just found a bookmark I had that was in the wrong folder. Appreciate the research and the link. I knew I had already looked this up but could not find it and was second guessing myself.
Thanks again!
