In searching for the play in my steering, I found this part of the steering shaft to be the culprit. There is no bolt holding it together or any adjustment. It looks like it just slides together. Is there any way to fix the play here, or will I need a new shaft? The rag joint is fine so its not that. I can clearly see the upper tube moving around in the lower tube before the bottom of the shaft begins to turn while turning the wheel and looking under the dash. Any help is appreciated.
