I put a steering column from an 88' mustang into my 92. Everything fit no problem but I noticed before installing it that the wheel spins around without the key in it, it doesn't lock. Also, once it was put in there is a lot of play turning it back and forth, this is with the car off and the key out. Being that this is an adjustable column I tilted the wheel down and it looks like the bushing right after the tilt may be gone. How can I fix my problem?
Also, if anyone knows which wires are for the horn I'd appreciate it... I need to wire the horn up because the plugs are different from my 92.
Thanks
Thanks
