Steering wheel Jiggle
  • Thread starter Thread starter Makdaddymac
  • Start date Start date Dec 26, 2007
M
Makdaddymac
323
orlando
Dec 26, 2007
  • Dec 26, 2007
My sterring wheel wiggles....it doesnt feal like column or pinions etc. nothing serious....it seems like a loose nuts and bolt thing up top.....so i was wondering is there a mount,or or rubber thing that holds it to stay still???? or a way to fix this...i could tell this is a common problem. cause my steering components are not shot!
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Dec 26, 2007
  • Dec 26, 2007
I posted about this exact thing a month or so ago....search for posts that i've made and you'll see it. I was told there is in fact a nut/bolt deal in there that can be tightened but i haven't gotten around to looking into it. Mine is BAD.
SuperStang83
1,693
Boyertown, Pa
Dec 26, 2007
  • Dec 26, 2007
Yeah, check under the dash and there are 4 bolts holding the steering column, make sure that they are tight.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Dec 26, 2007
  • Dec 26, 2007
being your sig says your car is a 88 I assume it has tilt. Mine did the same thing. I took the cover off that covers the column and it was a bolt that had came loose right near the signal/washer switch. take the cover off and wiggle the wheel and you will see what I mean. 5 min fix
fess40
292
Paris, Illinois
Dec 27, 2007
  • Dec 27, 2007
Might check the rag joint. Mine crumbled with age and created all kinds of play. Easy $10 fix if that's it.
M
mavmavv
185
  • Dec 27, 2007
Mine is the same way. I shoulda fixed it when I had the dash out last weekend for my heater core replacement.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Dec 27, 2007
  • Dec 27, 2007
Fox steering shafts have the rubber rag joint that gets weak too. If it isn't a column problem check that. My 91 was very sloppy, I didn't replace it, but I should.
04sleeper
2,674
14
89
Dallas, TX
Dec 27, 2007
  • Dec 27, 2007
+1. I have had this happen before in my 88 and 89.
M
Makdaddymac
323
orlando
Dec 27, 2007
  • Dec 27, 2007
ok well i'll check the rag joint(which where is that by the way) and also 'roland69" i will check that and repoert back to you...i was in the process of pulling the sterring wheel off...
M
Makdaddymac
323
orlando
Dec 27, 2007
#10
  • Dec 27, 2007
  • #10
and the winner is roland69" it was a 5min and free fix!!!!!!!!!!!!!! yes!!!!!!!! just tightened up the bolt and boom
-thanks to all
rd
3,316
63
109
Ocean Springs MS
Dec 27, 2007
#11
  • Dec 27, 2007
  • #11
I suggest checking 3 things:
The 4 bolts that hold the brackets for the column to the bottom of the dash. If these get loose the wheel and column will move around. Easy to tighten
The two pivot bolts in the tilt wheel setup. You will need to remove the plastic covers over the column. There is one on each side, and they look more like studs or headless bolts, but they are what the wheel pivots up and down on. Someone else described them pretty well here.
The rag joint. If it is worn, you will have play in the steering. Yours sounds like one of the other two though..
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Dec 27, 2007
#12
  • Dec 27, 2007
  • #12
glad to hear you figured it out...if could have been the other things mentioned but more often in a tilt column it is that easy fix lol
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Dec 28, 2007
#13
  • Dec 28, 2007
  • #13
Well that does it, i've gotta dig into mine tomorrow and take care of it. The last time i took it for a cruise it was blatantly obvious how much it jiggled. I'm certain that mine is right at the tilt section too because i've grabbed a hold of the column and tried to move it but it's tight, it's just the wheel itself that moves.
04sleeper
2,674
14
89
Dallas, TX
Dec 28, 2007
#14
  • Dec 28, 2007
  • #14
It's a pretty common thing actually.
For good measure, use a little Loctite on the threads.
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
