  • SN95 V6 Mustang Tech
stereo/cd player
  • Thread starter Thread starter calstang99
  • Start date Start date Nov 12, 2005
C
calstang99
12
  • Nov 12, 2005
I want to try and replace my radio/cd player in my 99 mustang cause after an hour of driving, the cd player eithers overheats or just hates me. I already have a pioneer deck from another car to put in, but i was wondering if i could just swap them out. A friend wanted to do the same for his 02 GT but said that there were amps and other things he would have to replace. Does anyone know if this is the same for the V6? If so, please help.
AndyG47
Jersey
Nov 12, 2005
  • Nov 12, 2005
Only if you have one of the Mach audio systems. It's the way the amps work as far as I know. If you're running the base system of 4 speakers and the radio itself you shouldn't have a problem. But remember an aftermarket radio will push your factory speakers (if you still have them installed) hard, and might blow them.
I myself have a pioneer cd player and speakers and everything works just fine. the speakers are even wired into the factory speaker wires.
You can't really see it but i simply cut the factory connectors and crimped the speakers onto the wires
http://photobucket.com/albums/a108/AndyG47/?action=view&current=rear9.jpg
C
calstang99
12
  • Nov 12, 2005
thanks a lot,
ill check the specs on the speakers and the stereo. as for the wires, that is what i had to do on the last car i had. thanks again for the help.
N
nctrader77
27
  • Nov 25, 2005
Install help
Changing over to an after market is not a big deal, with or with out upgraded factory amps. Metra co. makes wiring harnesses for either application. If you go with a high power after market unit you want an "amp by-pass" harness. Just call Metra tech support they are great. They have a
good web site, but they don't list everything they sell. That is why I always call them and tell them what I want to do, and they tell me what is needed. Also, changing just the front door speakers will make a huge difference.
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
Sloppy steering wheel
  • cnorman31
  • Nov 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2025
Monkeybutt2000
M
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
