Sticking Gas Pedal
SteedaGT9150, in addition to what Noobz347 and trinity_gt mentioned I will add that sometimes there is carbon buildup at the throttle blade. This will cause the throttle to stay open. You can spray it down with some throttlebody cleaner and see if that help.
I try to lube the throttle cable at least every year. Some oil on every linkage and a little down the sleeve helps a lot. You can use WD-40 or JB-80 to free it up initially but you need to follow it up with 3-in-1 or a couple drops of motor oil, as spray oils evaporate leaving little to no lubrication themselves.
It will stick if you ignore it.
Thanks guys ill check it out. It's a brand new trickflow intake and tb BTW...
Years ago I had the same problem when I bought my PP TB and upper plenum. The throttle was sticking open about a week after the install. I used some throttle body cleaner and it was fine. I had to do it again a few weeks later...after which I never had that problem. A shop told me that this sometimes happens with new TBs.
