sticking idle
Once you put the car in neutral and released the clutch pedal, what did the idle do?
Did this happen again? Did it feel like a mechanical sticking (like the TB butterfly or throttle cable) or like an engine management glitch?
I would pull codes nonetheless. A code can be stored even if the CEL is not on. This happens often with 'burps' that come and go pretty fast.
More info will help folks to help you.
Good luck bud.
Sounds mechanical to me. I mean if it was an engine problem it wouldn't have revved to 3000 just to keep from dying, IMHO. I would be willing to guess you have a sticking TB or cable/peddle problem. Have you taken the cable off recently for some reason? Did you adjust the position where the cable connects to the TB? Is it possible the cable is ran in a way where it got caught somewhere pulling back the tb? Have someone else get inside and see if they can duplicate. My guess is either a cable or peddle problem. Never seen a tb "stick" open before. Anythings possible.
TB butterflies can stick open. Some of the aftermarket units have screws on the butterfly axis to allow adjustment and some folks have had to hollow out the bore a little to keep the butterfly from sticking. This is almost always at WOT though.
jmd2914 said:
not all the time, its just every once in a while, ill be driving and it will kick up to 3000 and stick
If the problem clears when you turn the iginiton switch off & and then restart the car, replace the TPS.
jmd2914 said:
about how long does a tps last?
Apparently about two years. :rlaugh:
The TPS should be about a 15 dollar part - worth a shot. I try not to toss parts at problems if I can help it, but with an intermittant issue like this, it can be difficult to 'catch' it when it is acting up so you can troubleshoot it (you are not going to leave it idling at 3K RPM, and once you shut down and restart, it probably fixes itself). Might be worth tossing a few bucks at - esp based upon the wise-one who recommended it. :nice: :hail2:
jmd2914 said:
true, ill give it a shot and see how it goes, is there any way i can test the tps i have?
Here is some info that can help (pics and basic procedures).
For testing the sensor, I hook up as is done in the above-link. But then with the key-on (Engine off!) slowly open the throttle. Watch the Meter (an analog VOM works best for this test) as you open the throttle. The meter's sweep should be completely linear with no spikes or dead spots.
The thing is that your TPS probably tests fine - you would need to test it when it is acting up (has your idle stuck at 3K RPM), which is not very practical. That was my point above.
Good luck.
my$100project said:
TPS--Duh, Why didn't I think of that? J or Hissin have either of you had to work on the relatively new "TBW" (throttle by wire) cars yet? What a nightmare.
Not for me, and I hope that I dont have to any time soon. I am kind of an old-school kind of guy. I have read a bit about the Spanish Oak workings and I would not want any part of that.
I would add that JR is a high-tech guy, so he probably knows all about that stuff. :hail2:
