sticking throttle/pedal question
Kabuki_notch
670
394
113
Rochester, NY
I hope someone can help me trouble shoot this problem, When I push the gas pedal on my car it seems to stick at the highest point of the pedal then when I push it hard to just give it a little gas it's like I am giving the car too much pedal, It also seems too touchy, would this have to do with the spring on my throttle cable, obstruction or a faulty cable, These are the only things I can think of but if someone has encountered and has a remedy that would be great. Thanks
-Rob
I'd check your throttle-blade. Chances are that it's closing enough to stick in the bore (been there and done that).
You can:
Readjust the throttle stop so the throttleblade is cracked open ever so slightly.
On some TB's you can adjust the throttlestop butterfly (to better center it). There would be a couple of tiny fasteners holding the plate to the throttle shaft that you loosen and adjust.
Some crafty folks have done a little Dremel work to clean the bore up so it doesn't stick anymore.
Option #1 is easiest if that works for you.
Good luck.
I had the same problem. Adjusting the throttle stop screw helped a tiny bit. I eventually installed a new throttle cable and it went away completely. If I'd have known it was that easy I'd have done it ages ago.
hehe, im still having some problems I replaced the throttle cable it's still sticking how do I set the idle? I am going to try adjusting the throttle screw tommrow, it's annoying to drive when the pedal is stuck at the highest point :(
