Drivetrain Sticky clutch pedal
  • Thread starter Thread starter keel
  • Start date Start date Jul 31, 2025
First Prev 2 of 2
Admin Dude
Jan 4, 1985
43,346
21,543
234
Box behind Walmart
Aug 5, 2025
#21
  • Aug 5, 2025
  • #21
keel said:
How is disc brake grease vs. something like white lithium grease?
About the same. The only thing it's really good for is the break-in period while everything gets itself seated.
More is not better and can gum things up when the dust and dirt collects.
Apply a thin coat expecting it to wear off as the parts wear in.
All of the "goo" is not your friend.
Reactions: keel, General karthief and limp
AeroCoupe
6,097
4,192
183
Claremore, OK
Aug 6, 2025
#22
  • Aug 6, 2025
  • #22
Disc brake grease is a high temperature, high pressure, synthetic grease and where white white lithium grease is a low to moderate temperature, low to moderate pressure, petroleum based grease i.e. general purpose.
The temperatures in the bell housing can be high when working the drive train so I opt for a grease that will stay where I want it to stay.
keel
258
113
53
Seattle, Wa
Aug 11, 2025
#23
  • Aug 11, 2025
  • #23
Replaced all the stuff I mentioned earlier and used high temp disc brake grease. Got the car up and running again today and so far so good!
I also adjusted the clutch to engage closer to the bottom of the range of motion of the clutch pedal so hopefully that will relieve some of the pressure I was putting on stuff by having the cable adjusted tight.
Reactions: Mindseye007, limp and gkomo
Mindseye007
10 years still blowing strong
5 Year Member
Oct 21, 2020
586
137
63
ontario
Oct 17, 2025
#24
  • Oct 17, 2025
  • #24
keel said:
My clutch pedal feels sticky when I let it out slowly at low speed conditions like reversing or parking. I already replaced the clutch cable which did not fix the issue. It feels fine when shifting normally and moving the clutch pedal more quickly.
I'm wondering how I can fix this, I was thinking that replacing the bushings in the pedal box might help but I really don't want to pull the pedal box without knowing for sure.
I had the same problem you had and my clutch pedal was also squeaking every time i shifted gears it drove me nuts, got some new clutch pedal support bushings from LMR
https://lmr.com/item/LRS-2471A/79-04-Mustang-Clutch-Pedal-Support-Bushing had them installed and my problems were solved so smooth now and quiet no more squeak.
Reactions: gkomo
First Prev 2 of 2
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
N
Sticky Throttle
  • NooStang
  • Jun 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
General karthief
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
