sticky gas pedal
  • Thread starter Thread starter jmd2914
  • Start date Start date Nov 7, 2005
J
jmd2914
937
Napa, California
Nov 7, 2005
  • Nov 7, 2005
alright, my gas pedal is sticking alittle bit when i first press it. wondering what would make this happen.
M
mackey
1,284
Beverly, Massachusetts
Nov 7, 2005
  • Nov 7, 2005
New throttlebody spring? Mine wore in after a while.
dkins419
187
Michigan
Nov 7, 2005
  • Nov 7, 2005
I took a can of carb cleaner that sprayed my throttle bottle and all around by the cable. It worked for me.
Grandmaster
374
Monticello, Arkansas
Nov 7, 2005
  • Nov 7, 2005
Yeah i had this problem for a while and it was really annoying, i would have to jab the throttle just to unstick the pedal. What you can do if i remember correctly is adjust your idle screw to where it would be idling higher, so that the initial position of the butterfly or whatever is past the point to where it used to stick. If this fixes the problem, then you'll know that it was in fact the sticky butterfly in the TB. So just clean that up so that it wont stick anymore, adjust the idle back down, and you'll be good to go.
Other than that you can always make sure the cable isn't getting crimped anywhere etc.
bubba-dough
1,044
Indiana
Nov 7, 2005
  • Nov 7, 2005
Is it a new tb...maybe a professional products????
HISSIN50
34
129
Nov 7, 2005
  • Nov 7, 2005
Yep, get under the hood and open the throttle with the throttle linkage itself. If it sticks there, you just removed the cable and gas pedal as being it.
Grandmaster's advice is an easy fix (or whipping out the dremel).
Good luck.
stangjunkie
381
  • Nov 7, 2005
i have this problem too, however i think its the driver...
HISSIN50
34
129
Nov 7, 2005
  • Nov 7, 2005
The throttle should not bind, no matter who is driving.
Car RamRod
Banned
Mar 30, 2005
623
Queens, NYC
Nov 7, 2005
  • Nov 7, 2005
I have this problem too, I just never remembered to ask about it.
J
jaackal
402
NJ
Nov 7, 2005
#10
  • Nov 7, 2005
  • #10
move the idle screw if its brand new it might stick and u'll hear a pop when it lets loose
bgjohnson
963
johnston,iowa
Nov 7, 2005
#11
  • Nov 7, 2005
  • #11
DITTO!
i bought one of these"fine" pieces of junk and it stuck first opening and all the way open, not to mention the whistle from it was louder than my flowmaster dumped. Somthing else i noticed when i was trying to delete my IAC, without that bypass around the throttle plate, the vacuum was so great on that plate it would stick until sufficient air flow got past it. really anoying.
somthing you can try is take the ball that is part of the linkage, polish it with a scoth brite pad and lube up the linkage.
J
jmd2914
937
Napa, California
Nov 7, 2005
#12
  • Nov 7, 2005
  • #12
nope stock throttle body and not a new idle screw, and its only alittle stiff when i first step on it after that its fine, should i clean the spring?
Grandmaster
374
Nov 7, 2005
#13
  • Nov 7, 2005
  • #13
The method i posted above is a pretty good way to start pin-pointing the problem. Just adjust the idle screw in to raise the idle, and if that fixes the problem you'll know it was a sticking butterfly. If that doesn't fix it you'll know it's something else. It'll take just a sec to do and check.
K
KeithGT
15
BG,Oh
Nov 7, 2005
#14
  • Nov 7, 2005
  • #14
when i was having idling prob, i accidently fixed this prob...all i did was clean out my throttle body with a spray cleaner...just take some cleaner and open your throttle body and spray where the butterfly usually sits...its prob just got a carbon buildup and its making it stick
Drivetrain Sticky clutch pedal
  • keel
  • Jul 31, 2025
Fox 5.0 Mustang Tech Oct 17, 2025
Mindseye007
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
Engine 86 GT heavy throttle pedal
  • 86 Convert
  • Sep 4, 2025
Fox 5.0 Mustang Tech Sep 4, 2025
86 Convert
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 9:54 AM
keel
