So far I have been having no luck working out why my c4 wont shift at wide open throttle. It revs all the way out to 6700 rpm and still will not shift! I have tried playing with the kickdown, and fiddling (rotating 2 times ccw) with the vacuum modulator with very little in the way of results.
The vac modulator does not appear to be leaking fluid - can it still be malfunctioning? It was replaced less than 1500mi ago and seemed to be good for about 1000mi.
I was under the impression that even if the modulator isnt working the governor should kick in at some point (5-6k) and force a shift. I dont think I can go any higher than 6700 to see if its going to shift without endangering my engine.
I am scheduled to goto a track day in 36 hours so any help is much appreciated!!
