still haveing problems :(
68_stanger
131
Petoskey, MI
Well you may recall my other post about my 68 that has a hot start problem. I bought a phenolic spacer and that didn't help, I bought a electronic igition that I was gonna buy anyways, and it helped but the problem still exists. I do have a couple questions regaurding this issue.
1) I am running a serpentine setup with a reverse flow pump. Is there anything else that should be changed to do this or just the water pump?
2) The radiator that Im running is a direct replacement for the orginal would an aluminun radiator help this the car and me keep our cool?
3) How cold of a thermostat can/should I run?
Thanks
1) no
2)yes
3)For the street I wouldnt go below 160 or it will start to stumble, 180 is good.
Refresh our memory on you hot start problem please
Does it crank over good or is it slow, What engine ,intake, carb, compression.
